'36 Chevy Wheels on my '54
Discussion in 'The Hokey Ass Message Board' started by Westside Lefty, Nov 18, 2007.
  1. Westside Lefty
    Westside Lefty
    from Venice
    Any ideas on how to pull it off. I will not run billet adapters. I know they're 6 lug. Any help is always appreciated.
  2. finkd
    finkd
    Ummmmm.......maybe Redrill The Hubs And Axles ??
  3. squirrel
    put 51-59 truck hubs and drums on the front, put a truck rearend in the back
    or redrill the axles in the back if there's enough meat on them, but I doubt it.
  4. Westside Lefty
    Westside Lefty
    from Venice
    Will the 51-59 truck hubs and drums mate right up? I can turn a wrench but my fabricating skills leave alot to be desired.
  5. Westside Lefty
    Westside Lefty
    from Venice
    I doubt it also since I'm running an S10 rear end. Any other ideas?
  6. Speedy Bill [Speedway motors] does sthe machine work to mount 54 chevy car front hubs on 50s chevy pickup spindles [just backward from what you're doing] so I know there's some machine work to be done but I have no idea what it is.
    Also, if they're made like early ford wire wheels, check to see if the 6 lug wheels will bolt-up to the 50s hub/drums. Fords have an extra lip that causes mounting problems, even though they're the same bolt pattern..
  7. squirrel
    no machine work required to interchange 51-54 car and 51-59 truck hubs/drums. Take off the old ones, put on the new ones (pack the bearings and change the seals and maybe turn the drums if they need it, of course)
  8. Westside Lefty
    Westside Lefty
    from Venice
    Squirrel...I....don't know how to say this.....I love you.
  9. Omega
    Omega
    from Mass
    awww thats cute :p
  10. Kurt
    Kurt
    will those old spoke wheels handle the extra weight and power of a much bigger car?
  11. Westside Lefty
    Westside Lefty
    from Venice
    Short answer is yes. I've seen it done
  12. Wasahawaiianrat
    Wasahawaiianrat
    i looked into doing this on my 54 too, i would just use wheel adapters in the rear for the s-10 rearend, they make non billet adapters....im SUPER curious to see what these would look like, could never find someone who did them on a 54 or even a photoshop version. do you have any pics?
  13. manyolcars
    manyolcars
    I have a set of two and a set of four 6 lug wire wheels, thats two different tire sizes, will sell
