What would you use to convert to power steering on this truck. It has the original front suspension. Who also has a kit or what to use for disc brake conversion on the front. Checked speedway no luck. ECI has brakes but they start a 1937 this truck is a 1936 what is the difference.
Your light weight truck really doesnt need disc brakes to safely stop. Install 40 backing plates all around with a hydraulic system and you will be pleased. POWER STEERING???? why??? That truck does not need it at all. Rebuild your existing setup for a fraction of the cost. These fords handle great with the stock suspension.
