Radiator ? 48 ply
Discussion in 'The Hokey Ass Message Board' started by i275, Jul 24, 2007.
  1. i275
    i275
    Have a 48 ply with a 350 olds in it , any ideas what radiator i could use ? THANKS
  2. Beetle
    Beetle
    from Texas
    Wow, I thought I was the only one with a 48 Plymouth with an Olds 350 motor. I had the original radiator recored with a high efficiency core, but I haven't run it yet. The tanks won't let it hold a lot of pressure, the guy that did it said I had to use a 7 psi cap.
  3. i275
    i275
  4. i275
    i275
    Try again ? I have 350 olds in it right now but will have 455 olds in the spring. so will need a better radiator. THANKS
  5. George
    George
    Might not be very helpfull, but my 48 came with a '73 Cutlass front clip & 455. Possibly the radiator is from the donor car, 25" wide & 22" tall.
  6. plym49
    plym49
    from Earth
    Just use the stock 48 Plymouth radiator. It will do the job better than the rad that came in the car your motor is from.
  7. ChevyRat
    ChevyRat
    Tons of aftermarket radiators out there that work better than the stock ones. Just measure the area you have to work with and find the ones that will fit. I use an AFCO which works great.
  8. Billa212
    Billa212
    from Milwaukee
    Griffin will custom make you an aluminum radiator to your specs...last one I did was about 500 bones
  9. plym49
    plym49
    from Earth
    Why would you say that? Have you ever tried runmimg a V8 behind that particular radiator?
    As a matter of fact, for quite some time I used those Plymouth radiators as the preferred choice in various engine swaps. They have a good fin design and do a good job of transferring heat.
    Most aftermarket parts are designed to separate a person from their money. Unless you need the bling factor, that stock rad is the way to go.
  10. 4woody
    4woody
    I don't know about your switch to the big block, but I run a 350 with a re-cored stock 38 Mopar radiator. It works ok with a 4lb cap. Been running it 2 years now.
  11. lowkroozer
    lowkroozer
    try a 70 to 73 Duster or 340 hypo Mopar and have it 3 cored
  12. ChevyRat
    ChevyRat
    The stock radiator was more expensive. I paid $240.00 for my AFCO and it works better. Do your homework. AND yes I run a V8 (400 small block)
  13. 41 C28
    41 C28
    I used the original mopar radiator in my 48 Dodge. had a new filler neck installed and running a 4lb cap. Running a 318.
  14. Crease
    Crease
    Different car, same story. I have a 40 dodge with a 360 and eneded up recoring the stock. I run a 4-5 pound cap and have never had any problems. Not many folks are recoring these days and it tends to get expensive and good quality can be hard to find. If I had it to do over again, I would just buy a custom from Walker, US Radiator or Griffin.
