Technical raise the front on my 32' transverse spring
Discussion in 'Traditional Hot Rods' started by Harley Charley, Mar 22, 2023.
  1. Harley Charley
    Harley Charley
    I need to raise the front end 1" on my 32' pickup. I just put a 502 crate motor in, and apparently missed the sweet spot on the motor mounts, and need to get it up. I was thinking about putting a 1" aluminum spacer between the spring and the perch. It's got a 4" drop axle now, but I don't see a big selection of 3" axles out there. Any advice would be welcome. Thanks!
  2. deuceman32
    deuceman32
    Do you have a reversed eye spring? If so, you could go back to a standard main leaf and get an inch maybe inch and a quarter back.
    427 sleeper likes this.
  3. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Do you have a stock or reversed eye spring? If it's a reversed eye there's an inch to be had there. Possibly a new spring with more arch?
  4. twenty8
    twenty8
    Are you sure you didn't lose the inch due to extra weight of the 502 ???
    Maybe the spring you have will need some leaves added to compensate.
    INVISIBLEKID likes this.
  5. swifty
    swifty
    I gather the engine is sitting too low and you need to raise that ? Why not make a packer/spacer between the engine and chassis based on your style of mount.
  6. Harley Charley
    Harley Charley
    Thanks for the response, Swifty. Sadly, I don't have enough clearance between the bell housing and the trans. tunnel. It's too bad, because I have pancake mounts and it would have been easy to slide spacers in!
  7. Harley Charley
    Harley Charley
    I had a 58' 392 hemi in it before, with hot heads on it, so I think it's a push on the weight. I might try adding a leaf or two... Thanks Twenty 8!
  8. Harley Charley
    Harley Charley
    To tell the truth, I don't recall if I put the reverse eyed spring in or not. I may have thought the 4" drop in the axle was enough. But I will check that out. Thanks!
  9. Harley Charley
    Harley Charley
    Thanks! I built it 5 yrs. ago, and I can't remember if I put the reversed eyelet spring in. I've reached the age where the other day I got up and walked across the shop and had to return because I forgot the reason I was going! Getting old sucks.....
    427 sleeper and panhead_pete like this.
