Technical ***January 2023 Banger Meet Thread Another trip around the sun***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jan 2, 2023.
  1. Looking good!!!
    stubbsrodandcustom likes this.
  2. Someone mentioned that you can't convert a governor drive as it isn't the same size of gear as the crank gear.
    Can anyone confirm whether someone can do that or not?
  3. Dan from Oakland
    Dan from Oakland
    Has to run crank speed, so the gear must be 25 teeth. If so, it will work as a side drive.
    Outback likes this.
  4. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Some old tractor mags had gear reduction built into the mag if I am right?
  5. Dan from Oakland
    Dan from Oakland
    The mag still has to run crank speed. Yes, there is a 2:1 reduction in platform mount mags to make the rotor run at ½ crank speed. Mags like a Vertex or Wico must run at cam speed- that why they run off the distributor drive gear train.
    Outback likes this.
  6. Fabber McGee
    Fabber McGee
    Dan is correct. Any 4 stroke engine, distributor or magneto, the rotor has to make exactly one revolution for each two revolutions of the crankshaft.
    Outback likes this.
  7. I really need supervision in the shop
    Mock up going into coupe….
    burl, BiscayneBrain, Old Dawg and 7 others like this.
  8. Dan from Oakland
    Dan from Oakland
    Outback and 4bangerbob like this.
  9. Outback
    Outback
    from NE Vic
    That does look dangerous...
    I think you should be left to your own devices more often! Haha
    johnneilson and Old Dawg like this.
  10. 282doorUK
    282doorUK
    Outback and Retson the Racer like this.
  11. Jiminy
    Jiminy
