Projects United Pacific 5W Deuce Build
Discussion in 'The Hokey Ass Message Board' started by Groovy, Feb 18, 2017.
  1. 64krusty
    64krusty
    looks close in the pic, but I have about an 1\8 of an inch clearance
    brEad, The 39 guy, ct1932ford and 4 others like this.
  2. nunattax
    nunattax
    from IRELAND
    i like your approach to the column firewall/floor mount.definately consider similar in the future with a flange welded to the column and bolted to the floor.
  3. Anderson
    Anderson
    Nice clean build!
  4. Groovy
    Groovy
    Interior h IMG_5531.JPG IMG_5532.JPG IMG_5533.JPG IMG_5530.JPG IMG_5534.JPG IMG_5535.JPG IMG_5536.JPG eader panel is painted and installed...
    The 39 guy, AHotRod, 40FORDPU and 9 others like this.
  5. panhead_pete
    panhead_pete
  6. Groovy
    Groovy
    Shoulder harness and IMG_6075.JPG IMG_6071.JPG IMG_6074.JPG 1/3 of the rear panel installed...
  7. Groovy
    Groovy
    Rear corner aluminum mostly done... IMG_6085.JPG IMG_6084.JPG IMG_6086.JPG IMG_6082.JPG
  8. Groovy
    Groovy
    IMG_6134.JPG IMG_6137.JPG IMG_6138.JPG IMG_6139.JPG IMG_6140.JPG IMG_6141.JPG IMG_6181.JPG IMG_6183.JPG IMG_6190.JPG IMG_6192.JPG IMG_6122.JPG IMG_6123.JPG IMG_6112.JPG Interior panel are painted and installed. Seats are installed. Hood lacing is installed. Making brackets for the Dzus fasteners... also painted my Brothers 67 Chevelle Wagon
    The 39 guy, AHotRod, alfin32 and 3 others like this.
  9. Groovy
    Groovy
    Gas pedal & throttle cable IMG_6201.JPG IMG_6204.JPG IMG_6203.JPG IMG_6205.JPG IMG_6202.JPG is in and foot perch has been welded up...
    The 39 guy, brEad, alfin32 and 2 others like this.
  10. Groovy
    Groovy
    Dzus fastener are being installed... IMG_6220.JPG IMG_6219.JPG IMG_6217.JPG IMG_6218.JPG
    The 39 guy, brEad, Bcap55 and 3 others like this.
  11. lcfman
    lcfman
    from tn
    Watching your build looks good. I am building a UP 5 window myself and am at the point I need a steering column.
    What column is that you are using?
  12. Groovy
    Groovy
    That came from Speedway... It is called NOSTALGIA Steering Column.
  13. Groovy
    Groovy
    Throttle foot support is sandblasted, filled, and IMG_6211.JPG IMG_6212.JPG IMG_6221.JPG IMG_6222.JPG IMG_6223.JPG primed...
  14. Groovy
    Groovy
    Hood sides are roughly cut out for the header stacks. Shifter has been bent to clear the arm rest. Still have to bend top back for easier reach... IMG_6233.JPG IMG_6243.JPG IMG_6245.JPG IMG_6238.JPG IMG_6239.JPG IMG_6242.JPG IMG_6236.JPG IMG_6237.JPG
    brEad, Bcap55, Chief 64 and 1 other person like this.
  15. Groovy
    Groovy
    Throttle foot pad is finished and installed. Have to wait a few more days for the paint to harden up before I set the rivets... IMG_6262.JPG IMG_6261.JPG
    brEad, The 39 guy, Chief 64 and 2 others like this.
  16. Groovy
    Groovy
    Hood sides have been cut and Dzus hardware is measured up and ready to be tacked on... IMG_6273.JPG IMG_6272.JPG IMG_6270.JPG IMG_6268.JPG
    brEad, The 39 guy and lurker mick like this.
  17. Groovy
    Groovy
    IMG_6307.JPG IMG_6296.JPG IMG_6297.JPG IMG_6296.JPG IMG_6298.JPG IMG_6299.JPG Hood sides are finally done...
    brEad, old skoool and Xman like this.
  18. Groovy
    Groovy
    I made a bracket for a clutch return spring and got more parts painted... IMG_6346.JPG IMG_6355.JPG IMG_6356.JPG IMG_6342.JPG IMG_6351.JPG IMG_6349.JPG
    lurker mick, dlw1932, brEad and 2 others like this.
  19. DDDenny
    Nice work there!
  20. X2!
  21. Groovy
    Groovy
    Pipes are finally done and painted... IMG_6418.JPG IMG_6420.JPG IMG_6421.JPG IMG_6424.JPG IMG_6431.JPG IMG_6432.JPG
    brEad likes this.
  22. Groovy
    Groovy
    Hood sides are epoxy primed and installed while car hibernates for winter... IMG_6597.JPG IMG_6596.JPG IMG_6595.JPG IMG_6594.JPG IMG_6593.JPG IMG_6592.JPG IMG_6591.JPG IMG_6599.JPG IMG_6598.JPG IMG_6591.JPG IMG_6590.JPG
    brEad, dlw1932, Chief 64 and 2 others like this.
  23. WiredSpider
    WiredSpider
    Nice work and nice car but the exhaust is too rat rod/clown car for me
    nunattax and milwscruffy like this.
  24. dalesnyder
    dalesnyder
    Cars looking fabulous. I like that color on your brothers wagon too..
  25. Groovy
    Groovy
    I know it's not for everyone but sometimes you gotta try something different...
    Randall and Chief 64 like this.
  26. Are you not able to heat the shop enough to work in the cold?
  27. Groovy
    Groovy
    Garage is 60 years old with ZERO insulation. Not worth spending large amounts of money on heat to tinker around.
  28. SDhotrod
    SDhotrod
    The exhaust looks like a WW II fighter exhaust. I kind of like it.
  29. Groovy
    Groovy
  30. Dick Stevens
    Dick Stevens
    As long as the hood stays on you won't see that weird setup, I'm wondering what it will sound like!
    brEad likes this.
