Still working on my wife’s 40 pickup build. As many of you know I am using all 40-41 sheet metal save for the cab which is a 42-47. Looking at my picture there are two holes on the cowl lip to mount the hood supports. So for those who are using/have used a later cab for a 40-41 pickup build which hole did you use? Or did you have to drill one? And if so, what is the measurement from of the top of the lip to the center of the hole? Thanks for any help you can give. TomT
I haven't done this and don't have any answers for you. Just wanted to let you know my '46 uses the bottom hole. Good luck!
The way I understand it it as far as 40 coupe’s and sedans go, the hood support bracket has a tab on it that uses both holes like at the bottom of this picture
The 40-41 Ford pickup uses the 39 Delux hood support arms without the tab - it’s just a single hole . From Drake’s Catslogue
I think it’s the top hole. You can check by putting the hood on the hinges then pooping the hood up with a pole. The support arms will be completely extended on their stops. Put the bolt in the hood and see which one is closest. It its on the top hole and it feels like to much pressure, move it to the bottom hole and the spring will have to be stretched less to close the hood, but the full ope position will be slightly lowere. Bu like I said. I believe it’s the top hole.
Just a side note...the Drake catalog doesn't list it, but the hood support arms on the '42-'47 are the same as used on the '40-'41.
I have the same thing going on looks like I have mine mocked up in the bottom hole . not sure that's right I was just talking about getting back to work on it. still don't have the cab bolted down solid need to finish the rear cab mounts
I can send you a measurement from my stock 40 pickup from the firewall lip to the hole if you like, all stock springs and hinges.
Post that measurement for all us to have please. I still have to fit all of that and this will make things easier.
So my 40 only has 1 bolt hole. It is 5” from top of rail to centerline of bolt hole. also the fender only attaches at the bottom bolt hole out of 3 in the cowl.
^^^^Excellent pics @buzz4041 . I don't want to go all Capn Jack Sparrow here but would you be kind enough to tilt that camera up and show me the hood attachment points? I have never had the hood on it so I am in the dark.
I hope this is what your after for hood attachment points. If not let me know and I will try my best to get what you need.
I looked at my 47 cab and it has the hood hinge supports from the top hole in this cab FYI. That was from when it had a 47 hood on it.
Yes it is current. I carry this one in the back of my home away from home living quarter trailer and tinker with it in the evenings after work. It is a tight work area now since puting cab on the chassis, but I keep plugging away at it. That is why I pay so much attention to your thread Bandit.
@buzz4041 I do believe I have trailer envy. I thought mine was nice but... Do you have a thread on that PU?
No sir I never started one. It would be a very old one if I did. lol I spend more time in this trailer than I do at home over the last 5 years.
