I’m looking to put the gas filler in my 57 Chevy cameo truck behind one of the rear lights to shave the filler. does anyone know of a kit or way of doing it that’s neat? Anyone done it on a cameo?
You may get some ideas here: https://c10crewcab.com/ Another possibility, https://www.rockyhinge.com/1955-chevy-taillight-conversion-kit.html
Another idea here 1955 Chevy Taillight Conversion Kit (rockyhinge.com) There might be Asome ideas to borrow there. They put a serous amount of thought and work into that unit.
Are you going to put a tank in the rear of the chassis as well? I’d hate to dribble fuel in from the taillight to the cab.
I want to take the tank out of the cab and put something under the bed ahead of the rear end. It’s having a c4 rear. I’ve just found this picture online and currently trying to figure what it is and how it works!!
If you blow up the picture it looks like a linear actuator moves the tail light open and closed. Thats how I did it on my 49 Buick.
Any chance you’d have some pictures of your installation? Really keen not to have something that rattled around or that damages the light unit itself. They’re $1500 a pair I’ve just found out
Here are the only pictures I have which doesn't so the actuator or the hinge. Notice the pin on the taillight and the round hole on the body that locates the taillight in the correct position every time. I made the hinge from flat stock and threaded rod and nuts welded so it would pivot on the rod using the nuts for hinges. Hope that made some sense.
