Auctions
1950 F-1 Price drop, $20,500
Discussion in 'Cars For Sale' started by charleyw, Sep 15, 2022.
  1. City: Broken Arrow
    State: Oklahoma (Boomer!)
    Price: 23,500
    I’ve had this truck since 1991 and have done most of the work myself. As you can see, I’m at the point where I need to finish the interior and I’ve just lost interest. I’ll probably regret it later.
    I strongly suggest that if you’re interested that you examine it in person and form your own opinions. I want no surprises on either side. It needs finessing but has great bones. More pictures in my albums.
    · 3” chop, new etc. replaced firewall, floors, trans tunnel, filled vent (I know, mistake)
    · All steel except for rear fenders (glass)
    · Volare front suspension with Fatman dropped spindles, rebuilt steering box
    · Power brakes and steering
    · Centech wiring harness
    · New tires with new Torque Thrust “D” rims (or steelies with caps and new tires instead)
    · Repro running boards, tailgate, stake sides, etc.
    · Aluminum tread plate bed floor, bed liner sides, 4 tie-downs and fuel access door
    · Decent paint, Brooklands green, single stage urethane.
    · 642 miles on GM Performance 330 hp crate motor with serpentine accessory drive including a/c compressor
    · New Edlebrock carb, Carter electric pump (Just replaced a defective FiTech fuel injection unit)
    · Ram’s horn manifolds, 2.5” exhaust out the back
    · Walker radiator
    · Rebuilt TH-350, Lokar shifter, stacked plate trans cooler
    · 9” rear (3.00:1) on chassis engr. Springs, rear sway bar
    · Tanks gas tank, located in rear
    · Autometer gauges with tach
    · GPS speedometer sensor
    · Newport electric wiper
    · Back up camera
    · Stainless steering column, (1.5”) with 4 spoke stainless steering wheel
    · I have glove box door, glove box, ash tray and all the other interior handles, escutcheons etc.
    · No side windows, Model specific New Relics power window mechanisms go with the truck
    · Vintage air and heat system loose, not installed (compressor is mounted as part of GM package)
    · Take-out leather buckets (power with heat) not connected
    · Lap belts
    · Oklahoma title in my name, currently licensed and insured.
    guthriesmith, missmuriel and catdad49 like this.
  2. Bump, Now $20,500
