Put a little to much on a stud the other day and and ran the nut on with an air gun and it flew out and went in my beard. Got real nervous thinking I would end up looking like the tin man. And The joke in my shop is if you get it on you it’s pretty much on your cat seat.
Talking about anti-seize with a friend, I wasn't sure if he knew just what I was talking about. He said, "yeah, the stuff you get on your hands and then you get on your sandwich and then on your girlfriend who then gets it on her boyfriend". Sure enough, we were talking about the same stuff. Lynn
The label on the Franks Red Hot bottle says: “I put that $&@ on everything “. Anti Seize is the same way when you get a tiny drop on you.
It's like a 5 yr old with a runny nose, 5 minutes he's covered in snot and so is everything within a 10 ft circle of him. .
Ten minutes? You must be working slow. Even before I use it, the stuff leaps out of the bottle on me! It works well, but is an unbridled mess!
I've got a small container of anti seize that I carried in my semi-trailer in the mid 1980's for lug nuts and trailer rocker pin nuts. I'm still using it to this day because a little bit is all you need. I agree, that shit gets everywhere you don't want it to.
The best stuff we had was in a can labeled by Catapiller<sp>. It was a bronze color. I say it was the best because it didn’t blend in to anything, kinda stood out so you knew you had some on you and could take a rag and wipe it off before you painted everything else with it.
