Projects 1930 Model A Coupe - New project coming up
Discussion in 'Traditional Hot Rods' started by Mikko_, Apr 8, 2022.
  1. Mikko_
    Mikko_
    from Sweden
    Sold my '53 Customline last weekend and a new project is already in the works, this time a Model A coupe.
    Thinking unchopped, full fendered, dropped axle, juice brakes and steel wheels.
    Hop up the banger a bit.
    Should arrive here in Sweden in a few months, car is being shipped from California.
    Plan is to drive the car as is during the end of summer/fall and carefully modify it during the winter.
  2. brady1929
    brady1929
    Congratulations.
    mad mikey likes this.
  3. 5window
    5window
    Very nice. Must be a chore to get it shipped.
  4. SPEC
    SPEC
    Looks like its ready to drive.
  5. Squablow
    Squablow
    Looks like a really nice car. I like your plans.
    mad mikey and Mikko_ like this.
  6. Mikko_
    Mikko_
    from Sweden
    Not really, my contact in the US handles all the contact with the shipping company.
    winduptoy, 5window and mad mikey like this.
  7. Mikko_
    Mikko_
    from Sweden
    Thanks for your comments, I'm very excited about this.
  8. MMM1693
    MMM1693
    I'll bet your excited! Great piece to start with.
    Mikko_ and mad mikey like this.
  9. That is a beautiful A.:)
    winduptoy, Mikko_ and MMM1693 like this.
  10. Ducbsa
    Ducbsa
    from Virginia
    My Coupe runs well with a 6:1 head and Mitchell OD, otherwise stock. You do need to listen to the motor to adjust the manual spark advance.
    Just Gary and Mikko_ like this.
  11. Mikko_
    Mikko_
    from Sweden
    Very clean under the car as well.
    JalopyJimbo, mvee33, Outback and 8 others like this.
  12. Mikko_
    Mikko_
    from Sweden
    Scored a set of 17 inch wire wheels, might use these instead of steel wheels as I was thinking first?
    Outback, GASSERBOB, winduptoy and 3 others like this.
  13. 36taildragger
    36taildragger
    from Folsom Ca
    I just scored almost the same thing here in Northern California!!! I’m excited to see your build progress, we can have some friendly competition. I want to do a similar build and keep it simple. My parts hord I have a 4” drop axle and drilled hairpins that’s going on next week. I’ll start a build thread and cc you, good luck and have a blast
    winduptoy likes this.
  14. Zax
    Zax
    1. 1952-59 Ford Social Group
    Wow, I bet you are counting the days until it arrives. Will it have to go through any kind of inspection process to get it legal to drive on the roads in Sweden?
    I'd probably let my '53 Ford go for a nice Model A coupe as well.
  15. dmar836
    dmar836
    So am I the only one who wonders.....
    Oh, never mind!
  16. gatz
    gatz
    very nice car !!
    Mikko_ likes this.
  17. panhead_pete
    panhead_pete
    Wow great score an awesome start.
    winduptoy and Mikko_ like this.
  18. Mikko_
    Mikko_
    from Sweden
    My initial plan was to use a drop axle too, now I'm thinking that I'll maybe start with just a reverse eye spring for a milder drop? Time will tell.
    Thanks and I'm gonna check out your build thread.
    Counting the days is a must, bummer the shipping got delayed so I will probably have to wait until late july/early august before it arrives.
    Yes, it needs to go through 2 inspections:
    First inspections is to get a Swedish title and license plate number.
    Here they weigh the car, measure it etc. Basically just checking that it is a Model A and not something else.
    Second inspection is a safety inspection where they check the lights, horn, brakes and so on.
  19. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Happy to see this. Always a passion of mine. Beginning in 1954, the year I started school.
    Mikko_ likes this.
  20. panhead_pete
    panhead_pete
    Mikko before mine shipped I bought an Oki Joe drilled 34 axle (not dropped), 32 Spring perches and a T spring. Also some 750/550 Firestone tires and had them thrown in the same container. Yet to fit the axle and spring but they are there when I want to. Perhaps some food for thought.
    Outback, WC145, winduptoy and 3 others like this.
  21. Mikko_
    Mikko_
    from Sweden
    Was thinking about that but I'm far from sure which direction I want to take this car so I decided to get it home and drive it as a stocker first to get a feel for the car.
    But it's a good idea, I appreciate it.
    panhead_pete likes this.
  22. PotvinV8
    PotvinV8
    Nice car, you'll no doubt have a lot of fun with it!
    Did a similar build on a '30 coupe. Here's what a 5-inch dropped axle, standard eye spring up front and a reversed eye, 7-spring rear pack on 16-inch wires (6.00-16s & 7.00x16s) combination will get you.
  23. Mikko_
    Mikko_
    from Sweden
    Looks great, thanks for the picture.
  24. Mikko_
    Mikko_
    from Sweden
    Well, one of the 17 inch wheels I bought ended up being to bad to use after sand blasting.
    Luckily there was an Early Ford swap meet/car show here in Sweden today so I went to have a look.
    And I found a replacement 17 inch wheel.
    Also bought a set of BLC 682-J headlights, I think they are gonna look great on the coupe along with a dropped headlight bar I still need to find.
    And some of the cars that attended the car show.
  25. sloppy jalopies
    sloppy jalopies
    along with those lights i like to run a stock model A emergency brake cross shaft as a front spreader bar...
    bought an extra one this am... check your local swapmeets !
    save that accuator bracket and remount as a driving light stand of horn/blinker/marker light bracket...
    also the brake rods with the eye on the end are great for mounting anything...
  26. synchro7
    synchro7
    Good looking project.
    Mikko_ likes this.
  27. Mikko_
    Mikko_
    from Sweden
    Wheels came out nice after blasting and powder coating.
    Still a bit torn though if I'm gonna use these or go with a set of '40 Ford steelies instead along with juice brakes.
  28. sloppy jalopies
    sloppy jalopies
    some of the guys may have some old pix showing Ford wires out front and 15" centers with reversed Buick outer rims out back, on early drag cars...
    Mikko_ likes this.
  29. Mikko_
    Mikko_
    from Sweden
    Found an old picture of a '29 coupe that has a great look IMO.
    Maybe something to aim for with my car...
    WC145, winduptoy, Jet96 and 5 others like this.
