Hot Rods T-Bucket runs after key is off
Discussion in 'The Hokey Ass Message Board' started by Gearhead Graphics, May 31, 2022.
  1. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Hey all, this one is getting me. My fiberglass bucket has started running 30 seconds to a minute after you turn the key off. Its' not the out of time dieseling that some do, just it runs with the key off a while before shutting down. I've checked grounds and all seem to be tight. wiring is all new (car is less than 2 years old) Running a Mallory ignition system with mallory coil and ballast resistor.
    Anyone point me to the next things to check out to get it to shut off?
  2. Primered Forever
    Primered Forever
    from Joplin,MO
    It’s feedback from the alternator. You need to install a diode in the charging wire.
  3. ^^^^YEP. That will fix your dilemma^^^^.
    lothiandon1940 and 427 sleeper like this.
  4. Atwater Mike
    Atwater Mike
    ...AND/or run that alternator wire to the 'accessory' side of ignition switch...
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Actually not a bad thing if you’re running a Stromberg 97 or a Holley 94. And an electric pump.
    Both are known to weep after the engine shuts down from the residual pressure.
    The engine running for a bit after shutting it down relieves the gas line pressure.
    mad mikey likes this.
  6. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Thanks guys, I'll look at the alternator and a diode, it felt to me like positive juice was leaking to keep it going, but haven't messed with this issue before
    427 sleeper and mad mikey like this.
  7. jaracer
    jaracer
    Just for the heck of it, try putting the key back in the ignitions switch and jiggling it towards the off position while it is running. If that doesn't do anything, I'm with everyone else that the alternator is feeding the ignition circuit with the key off.
    41 GMC K-18 likes this.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    A diode in the alternator will work. So will running it through a keyed relay. I smoked a diode because it was not of large enough capacity. The relay is reliable.
    Primered Forever likes this.
  9. Jethro
    Jethro
    I had that happen when I installed an electric fan. When I put a relay in it solved the problem. I guess the fan spinning when the engine shut off generated enough juice to keep the engine running.
  10. Yep, that is it, with the problem of run on that I had!
  11. Agree it's likely feedback from the alternator ignition switched exciter wire, or could also be from electric fan turning and acting like a small generator.
    For the exciter wire just need a diode. For the fan, running through a relay or a diode will fix it.
    ProtoTypeDesignFlauz and egads like this.
  12. Ebbsspeed
    Ebbsspeed
    Put it in the wire going to terminal #1, NOT the heavy "charging" wire that goes to the battery (or ammeter, or starter depending on how your car is wired).
  13. hotrodjack33
    hotrodjack33
    I had the exact same problem. Electric fan wired into the "run" side of the ignition...without a relay. As the fan wound down, it would send power back through the ignition and keep the car running until the fan completely stopped.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    While I'd jump on board with everyone else your wording has me thinking is this a new issue that never use to happen?
    hotrodjack33 likes this.
  15. 427 sleeper
    427 sleeper
    Unplug the alternator and see if the engine kill's properly.
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    Aww , where's the fun in that ?
  17. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Yes, recently started issue, hasnt been happening until last month or so
  18. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Thats an interesting possiblity, The new thing over the winter is a much larger electric fan. I havent tried running the car a short time before the fan kicks in and shutting it off. A relay is laying on the bench and needs to be installed, just had 100 other things i have to get done around the house too
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    There it is. The fan's motor as it spools down generates voltage that feeds back into the wiring loom. In this case the IGN curcuit.
  20. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Yep, @Johnny Gee I think that's the ticket, its the "new" thing on the car and seems to make just enough to bleed through. Ill have to put the relay to the top of the priority list.
    427 sleeper likes this.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    When I was wiring my 56 I elected to not use a relay for cooling fan because it wasn’t link to IGN. While testing things before any start up of engine I’d turn the key off only to have starter throw out the starter gear (main power to motor removed). I added a relay and all fine. I no longer have a electric fan but not for that reason.
  22. Hot Rods Ta Hell
    Hot Rods Ta Hell
    To rule the fan in/out, disconnect the fan (or pull the fuse) then do a run test w/o the fan to see if the engine shuts off properly.
  23. Mimilan
    Mimilan
    If you're using a stock ignition switch ,all Tri-5's have continuity between the Ign and Access at the switch.
    So if you hooked up a fan off the accessory it could keep the engine running on.
    They are really easy to hot-wire at the fusebox
    Just bridge a wire from the courtesy lamp 12v live to any spare post on the accessory circuit , it will make it's way to the coil.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I performed a continuity test to the switch before hand and didn't get that result.
