Hot Rods CA Hot Rod Deuce Coupe **Found***
Discussion in 'The Hokey Ass Message Board' started by JohnnyCASHcadillac, Dec 20, 2020.
  1. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I’ve never had a Stude engine. I guess I could talk to Tom Branch about that one….
    Stogy, Thor1 and SS327 like this.
  2. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    E7B82324-5C7D-4E38-83AC-9CB679241EF8.jpeg Going through my pics:
    I found more of that red.
    I am beyond excited to finally believe I have found my car.
    looks like I’ve got a version I am gonna build.
    chryslerfan55, Stogy, Thor1 and 2 others like this.
  3. SS327
    SS327
    There’s even more red paint than I could see before. Great job!
    Stogy likes this.
  4. KKrod
    KKrod
    you may be able to find the color history of the car if you are lucky. Look in the door jams for the best painted surfaces. Sometimes they are less exposed to the weather. Then take sandpaper and feather edge a spot in the paint showing the layers. Then rub some polish over the spot and you are finished. If you can find a prominent color that will help in tracking down the car.
    Example
  5. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    D9EE7813-AB34-4A9C-A9EF-4408988FBCD1.jpeg D66CBEA2-7C98-43F1-A7C9-7E26A98BBB2E.jpeg
    I tried that. My previous owner said every time they would have primer left at his work he would primer it. I haven’t been able to find any good blue when sanding
    but I did find these “blue spots”
    The deck lid has the least about of primer and other spray.
    chryslerfan55, SS327, Stogy and 3 others like this.
  6. KKrod
    KKrod
    Thumbs up. When you zoom in on the close up picture it looks like it has been dark blue metallic, black, and then the medium blue metallic most recently when . And then the preservative coats of paint and primer over that.
    The dark blue metallic and the black look pretty thick like they were the color of the car at one time. But definitely the light or medium blue metallic looks like the last color before the brush paint and primer by the previous owner. There may be other colors it has been too.
    chryslerfan55, Stogy and Thor1 like this.
  7. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  8. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I found MORE!!
    I’ve been crawling over this car for awhile and now all the parts are starting to “click” to where the car came from. I couldn’t be more excited!!
    I’d wish I can say I’ve 100% confirmed it but I would say I am 90% sure.
    chryslerfan55, SS327, Stogy and 2 others like this.
  9. titus
    titus
    in my opinion the red car looks to be chopped a tiny bit more, take a better more correct matching side shot and then do some scaling and you can figure it out for sure.
    i have a few 32 5 windows, 3 of them are chopped and all a little different amount from each other and the quarter windows show it.
  10. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    I’ll try
    I’ll try to set up the same angle…
