Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. Elvis100
    Elvis100
    Everything disassembled cleaned and ready to reassemble. Got the replacement axle today and a few other parts. Still waiting on some hardware.
    Stogy, loudbang, Squablow and 2 others like this.
  2. rusty valley
    rusty valley
    Boy you got lucky on that one. 354 gears and lots of good parts. My tudor needed 3 rears to make one, and still couldnt come up with a drive shaft that wasn't rotten on the front bearing
    Stogy and loudbang like this.
  3. Elvis100
    Elvis100
    Got back out in the shop today. Started by installing the pinion gear in the housing. Got the axles installed and the backlash set to .007
  4. Elvis100
    Elvis100
    More work on the rear end. Installed new studs, cleaned and painted with a polyurethane coating. Cleaned and painted the new drums. I’m using Steel-it coating
    Stogy, Cyclone Kevin, brEad and 5 others like this.
  5. Elvis100
    Elvis100
    Prepping the running boards for a test fit
  6. Elvis100
    Elvis100
    Rear end back together
  7. Elvis100
    Elvis100
    Did some final fitting and installed the rear spring. I have 2 inch drop shackles and I took out three leaves. I’ll see how it sits and I may change that later
  8. Elvis100
    Elvis100
    Got the left running board and left rear fender fit. Had to fill and re-drill a few holes. The reproduction running boards and reproduction frame rails didn’t play nice together. Got the right running board and fender offered up and I’m going to have the same issues.
  9. Looking good. Keep at it. Impressive build.
    Stogy, Elvis100 and loudbang like this.
  10. Elvis100
    Elvis100
    Made a body dolly out of some old frame rails. Completely disassembled the body in preparation for the running gear test fitting
  11. rusty valley
    rusty valley
    Cool ! I have one of those too, but sadly, the frame I used is so rotten it is barely good enough to store a body on.
  12. Elvis100
    Elvis100
    Off the rotisserie
    Stogy, Ottomotive, loudbang and 2 others like this.
  13. Elvis100
    Elvis100
    Worked on fitting the front fenders, they need a lot of work, but they are original and I can do most of the body work on them later
    mvee33, Stogy, Ottomotive and 7 others like this.
  14. Elvis100
    Elvis100
    More work on mocking up the front end sheetmetal. Wish I had some better inner fenders.
    Stogy, brEad, Ottomotive and 5 others like this.
  15. Curious how everything lined up. Usually takes considerable massaging.
  16. Elvis100
    Elvis100
    Pretty happy with how all the sheetmetal is fitting with the other pieces except the frame mounting holes. I figure I’ll push and pull everything where I want it and re-drill all the mounting holes. I kind of figured there would be issues after mounting the running boards and rear fenders.
    Stogy, brEad, vtwhead and 1 other person like this.
  17. Elvis100
    Elvis100
    Got the grill shell fully attached to the radiator and had to put on some jewelry. Next I’ll get the inner fenders lined up and bolted. The the right looks good and the left needs to come up in the back about 1/2 inch
  18. Elvis100
    Elvis100
    Got these A-pillar castings on instagram. Cleaned them up in Evaporust for three days and gave them a coat of Steel-it. They are nicer than the ones I have for the 33.
  19. Elvis100
    Elvis100
    Finished mounting the front inner fenders and started mocking up the front end. I’d like to say the rearend cart was designed with multi uses in mind, but it was just a happy coincidence.
    Put new bushings in a set of dropped spindles and reamed them out for a nice tight fit
  20. Elvis100
    Elvis100
    Dropped the steering arm and spindles. Installed the front shocks
  21. Squablow
    Squablow
    That's a damn nice looking grille! Glad to see this still coming along.
    loudbang, Elvis100 and rusty valley like this.
  22. rusty valley
    rusty valley
    Looks like later shocks you are using, no? did the bolt holes match up?
  23. Elvis100
    Elvis100
    Yes, bolted right up. I believe they are later replacement shocks made for 33/34. The body looks like a 40 ford, but the arm is dimensionally 33/34.
    brEad, rusty valley and loudbang like this.
  24. Elvis100
    Elvis100
    Update on the pedal conversion:-( . Unfortunately this modification looks elegant, but does not work. When depressing the clutch there is too much force exerted on the shaft that is also integral to the brake pedal. Result is not ideal. I have some other ideas. More to follow
    milwscruffy likes this.
  25. Elvis100
    Elvis100
    I’ve been working on other projects, but still getting a few things fitted.
    brEad, Squablow, el Roach and 3 others like this.
  26. Elvis100
    Elvis100
    Two day round trip to Trinidad Colorado to pick up a frame for the 33 off Craig’s list
    brEad, Squablow, cactus1 and 3 others like this.
  27. rusty valley
    rusty valley
    Prolly nice and clean from CO, or you wouldnt have gone !! good for you !
  28. Elvis100
    Elvis100
    Yes, and already bare metal. Also got a nice cowl with the deal
  29. Jhimmy
    Jhimmy
    You don't perhaps have some extra doors or bits of doors? I need a set of doors. Thanks
  30. Elvis100
    Elvis100
    Sent you a DM
