History When one flathead quits you "add" another one?
Discussion in 'The Hokey Ass Message Board' started by Ebbsspeed, Jan 20, 2022.
  1. Ebbsspeed
    Ebbsspeed
    Looks like the Ford crapped out, so they added a Cadillac with a Hydra-Matic in front of it. How did they keep the Ford crank oiled?
  2. Grease fittings on the mains accessed through the piston holes?:rolleyes:
    hotrodjack33 likes this.
  3. squirrel
    only need one grease fitting, where the oil feed from the pump is?
    that's a kickass truck
  4. lake_harley
    lake_harley
    Was that one of the images brought up in a web search for "contraption"?
    Lynn
  5. hotrodjack33
    hotrodjack33
    They probably just filled the crankcase up to the bottom of the cylinders with oil, so the crank/bearings were completely submerged.
    chevyfordman and VANDENPLAS like this.
  6. TCTND
    TCTND
    Doesn't look like the Ford has an oil pan; probably just lubricated with dirt like tank tracks.
    stillrunners likes this.
  7. dwollam
    dwollam
    WOW!
    Dave
    oliver westlund likes this.
  8. Wanderlust
    Wanderlust
    Just a smidge front heavy I think
  9. I'm guessing that they both were running at one time and when it was put out to pasture someone decided to strip the flathead. I love the connection between the two. Bet you couldn't wheelstand that one.
  10. Flathead was dead - Caddy motor ran a pump...........
  11. UNSHINED 2
    UNSHINED 2
    With all the power that Caddy engine made they had to mount it like that to keep the front end down!
    Max Gearhead likes this.
  12. lippy
    lippy
    from Ks
    There had to be a simpler way to accomplish the same thing? Whatever it was they were trying to accomplish! :D
    Tman and hotrodjack33 like this.
  13. blowby
    blowby
    from Nicasio Ca
    Those two bolts on the frame are working hard.
  14. fiftyv8
    fiftyv8
    from CO & WA
    That has been posted here a good number of years ago.
    Buddy tells me the Ford kept wheel standing the truck, so they needed more weight out front.
    Hahahahahaha....
  15. "Hold my beer and watch this"
    hotrodjack33 and fiftyv8 like this.
  16. spanners
    spanners
    Maybe the flatty was originally set up as a compressor ?
    hotrodjack33 and chevyfordman like this.
  17. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    What did they say??? Jess cause ya can don't mean ya should.
    Seriously, I once had nightmare that was worse.
  18. Rickybop
    Rickybop
    Farmers :rolleyes:.......................:D
    R A Wrench, Tman, jim snow and 4 others like this.
  19. the original r*t rod ... be easy to work on the engine .
    Max Gearhead and hotrodjack33 like this.
  20. I'd drive it.....
  21. bigdog
    bigdog
    Bet you could in reverse.
