Hot Rods The 911 gets a new driver
Discussion in 'The Hokey Ass Message Board' started by Pete, Jan 9, 2022.
  1. hrm2k
    hrm2k
    just so cool
    looking for updates
    loudbang and Stogy like this.
  2. indyjps
    indyjps
    Very cool build.
    A shop finally appeared in the pics. Post #4, I thought you guys just chose a spot in the road surrounded by woods and tore the car down. Like moonshiner- car builders.
  3. Pete
    Pete
    Kayleighs still up in the air about the grill.
    32 commercial or track nose...track nose flipped?
    3B9256B7-9E35-4CC5-9E5B-73D9EB8F1532.jpeg 15FB95FF-6185-4B6C-A87A-93E943EEA12D.jpeg 224D2148-93B0-4161-922C-FAFC6A6291B2.jpeg
    OFT, 48fordnut, Stogy and 10 others like this.
  4. Tim
    Tim
    from KCMO
    I liked the track nose flipped with the opening extended up some more.
    will it run a hood?
    Stogy and chryslerfan55 like this.
  5. PINEAPPLE
    PINEAPPLE
    Great job passing the torch. I have seen this on instagram. Cool to see more photos of the build on here!
    Stogy likes this.
  6. NoSurf
    NoSurf
    Looks great Pete.
    Maybe a Whippet grill?
  7. Tim
    Tim
    from KCMO
    Ok first we have a hood side added and the opening made taller 5AED342D-C5CE-4999-9F3E-8809F0B591B6.jpeg
  8. Tim
    Tim
    from KCMO
    2B28F44E-84DA-4CB4-8159-CDD86A5FA668.jpeg And then I chopped the whole grill/nose down to match the cowl a little better
    B Bay Barn, 48fordnut, Stogy and 3 others like this.
  9. Pete
    Pete
    I like it Tim!
    Stogy and Tim like this.
  10. Pete
    Pete
    Doing some real cheap and easy build techniques. Using angle iron to create the inner perimeter floors. Found a sheet of pre pandemic plywood in my shop. The sections will be bolted down to the angle.
    Remember this was an old torched/gutted race body so there was no inner structure at all. The wheel wells were cut out, b pillars torched.
    made a quick pair of bolt in aluminum wheel wheels,,, think I’ll engine turn them.
    0F04AEB4-34CE-4467-B94F-772E9E734175.jpeg 87A58A0D-5D16-48AB-A464-16D0C116C33A.jpeg D418516E-2149-4F5D-B289-6BFA3C77CAE8.jpeg
    OFT, 48fordnut, Stogy and 8 others like this.
  11. Tim
    Tim
    from KCMO
    If you’ve got any other ideas that a photo mock up would be handy let me know. Doesn’t take me very long to do a rough up like I posted.
    thanks for posting the build I’m really enjoying it
    Stogy, loudbang, TFoch and 1 other person like this.
  12. That looks good. Before the top of the nose was too high vs the cowl, at least visually it seemed to run uphill. Now chopped it flows down. I think the track nose matches the rest of the build. The old commercial grille looks more RR style.
    B Bay Barn, Stogy and chryslerfan55 like this.
  13. Pete
    Pete
    I agree...the nose was just propped in place with wood blocks for imagination purpose
    but it looks much better with the adjustments
  14. Tim
    Tim
    from KCMO
    Some of it is the low angle the photo was taken from I think. A further back/ standing photo would show us what’s going on a little better but it’s super cool either way you slice it
  15. Pete
    Pete
    A few updates on the T
    we started cutting and welding in some structural steel and adding floors.
    since this was a gutted race car there were no wheel wells...we made some bolt it aluminum ones,,,did a little free hand engine turning... not too bad. 0D37EAD1-B0F8-4BD4-B43F-DD9568F5CA27.jpeg 011EA322-8236-49BA-8B08-A221850FE27B.jpeg 33E7D18F-37D1-4260-B35B-D348331610CB.jpeg C3D4B6C1-74BD-4DFA-83D6-7B3246E5EB8D.jpeg
  16. Pete
    Pete
    The donor cowl had no feet and the steering box mount was inside the cowl I made a little cowl mount to support the front.
    D26A0824-DF68-4811-B2E3-982D152AC0CF.jpeg 1D244C58-F2DA-46C8-AB05-A067472A8E06.jpeg 29DECA19-4D54-4DA8-9827-EEEF40DF0D47.jpeg 75E1439D-7D5C-4802-B101-6841720EA0A5.jpeg
  17. Pete
    Pete
    5C6E23EF-32A0-4703-8203-4B69192B0D88.jpeg 0C0A7D42-5A2D-47E9-BE8E-4D648091FA55.jpeg F4D89B80-4029-4DEC-8570-DCDC4181CFFD.jpeg B2D32F80-E67E-4F87-8B90-A908917135DE.jpeg 4EFCF0E9-A9D2-46F9-9568-D5F5C2311EA6.jpeg B5C075BE-60F7-4E99-AE06-E06DCA0AD686.jpeg Kayleigh decided on a 32 shell so I ordered the radiator. It arrived and it was a bit too tall, put the grill shell higher than the cowl ... yuk
    So I recessed the crossmember, made pockets to lower the radiator,,, kinda killed two birds with one stone because now the outlets on the bottom matched and straight hoses can be used.
  18. Pete
    Pete
    I had a re pop 32 shell hanging on the wall. It looked goofy being full height on a 27T , you could see the front u bolts thru it.
    I removed 2” out of the height, just enough to hide the u bolts.
    5B7F52F0-4FF1-4825-A291-25013892EA94.jpeg BC4656E2-4105-48AF-B41A-717FAB596B4D.jpeg BC44C6DF-2100-4088-89D0-8C159811A0B8.jpeg F73FAA6F-D217-452A-84B8-69CC952D6956.jpeg C5F9F774-5F9C-4ABF-A598-0A02A9713B5B.jpeg
    OFT, 48fordnut, chryslerfan55 and 8 others like this.
  19. Mr48chev
    I liked the track nose and was ready to offer up a Jag style screen grill mesh for it but that cut down 32 shell rocks and screams hot rod. I'm digging that.
    Tim, TFoch, loudbang and 1 other person like this.
  20. Pete
    Pete
    I struggled a little with the radiator support rods,,,couldn’t decide what the simplest way was. I had a pair of model A mechanical brake rods in the scrap pile so I used them.
    Made a pair of quick L brackets, bent the rods and welded a single threaded rod on the other end.
    0054735B-0E39-4F21-8048-AD5DB5871835.jpeg F68828EE-04DD-4F60-972F-CE96AF58CAE9.jpeg CA882BEC-EEDA-4B08-A934-68F2DBE46B3C.jpeg 57955D64-7D0B-468A-8396-4086583D9A69.jpeg 63D2B403-786B-4F09-B837-6925A519F3C0.jpeg C891E7F1-17B8-4AFB-AB0F-DE8DFF028952.jpeg
  21. Pete
    Pete
    That was very of you
    I was honestly relieved, the track nose needs a lot of work to be used.
    Ill make an insert for the 32 with some stainless tube
    chryslerfan55, Tim, TFoch and 3 others like this.
  22. Pete
    Pete
    Some floors. Kayleigh and her dad are gonna sand and poly or paint them.
    47E64FF5-E13A-4E02-87E4-1ED11FF3C2B3.jpeg 414E21B9-84F9-4DD3-AD05-F651233E0BCB.jpeg BDA07559-D5F4-44FB-8835-4BCA2146C46C.jpeg
  23. elgringo71
    elgringo71
    This is a great thread for a good cause. Keep up the good work
  24. wheeldog57
    wheeldog57
    Nice Petah, coming right along. Looking forward to seeing it in person
  25. Nice work @Pete I like the way this is coming along!
    Stogy and loudbang like this.
  26. Tim
    Tim
    from KCMO
    Looking great! Thanks for the updates
  27. What a great project, way to start a youngster down the road to ruin !!!
    Stogy, loudbang and mcsfabrication like this.
  28. Tim
    Tim
    from KCMO
    Make sure to share how you go about making the insert!
    Stogy, chryslerfan55 and loudbang like this.
  29. Pete, love this thread for so many reasons. Hot rodding at it's best!
    Stogy, LWEL9226 and loudbang like this.
