Hot Rods Sun tach transmitter needed ?
Discussion in 'The Hokey Ass Message Board' started by putz, Jan 14, 2022.
Tags:
  1. putz
    putz
    from wisc.
    found a ol homemade gauge panel with 2 sw gauges and a Sun tach , hopefully someone can help identify the year and if a transmitter will be needed for the tach ....... numbers 621 41 331 ,
    range 10,000 ..........
  2. brokenspoke
    brokenspoke
    Depends on engine
  3. fleetside66
    fleetside66
    Could you post a picture of the whole works?
  4. 1934coupe
    1934coupe
    I believe what Brokenspoke said, more directly the tach will work with any SW transmitter "for the engine it's used on" ie 4,6, or 8 cal. magneto or not, 6 or 12 volts. A picture is worth a thousand words.
    Pat
  5. jimmy six
    jimmy six
    I’ve got a 12 volt 6 cylinder I’ll probably never use.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    It will say right on the back of the tach if it needs a transmitter and which one to use ... how about some pictures??
  7. putz
    putz
    from wisc.
    thank you all ...............
