Technical paint the inside of a bell housing; yes or no???
Discussion in 'The Hokey Ass Message Board' started by atch, Jan 9, 2022.
  1. spanners
    spanners
    I reckon lace with several coats of clear, sanded between coats of course. Should make it that heavy you'll never pick it up to install it.
    ClayMart and VANDENPLAS like this.
  2. Lakewood bellhousings are painted inside, should make for easier cleaning and protection.
  3. gene-koning
    gene-koning
    Paint it, that will help the oil run out of it faster. Gloss white would show the oil faster.
    lemondana likes this.
  4. klawockvet
    klawockvet
    Back in 1962 I pulled the flathead out of my 33 coupe and put a 327 in using an adapter to mate it to my 40 sideshift trans. My buddies and I would drink heavily during those times and we discussed the need to build a scatter shield. For whatever reason I decided it was not needed but one of my wise ass friends said I should at least paint arrows on the inside of the bellhousing so the clutch pieces would know which way to go if it came apart. Since the housing and trans bell were painted I went ahead and painted some black arrows on the orange painted parts. The coincidence with this thread is that I happened to move that transmission a couple of weeks ago and smiled as I saw those arrows still evident after all these years. So to answer the OP's question, yes I would paint the inside of the bellhousing, which I do for any parts that are exposed to outside elements that are constantly exposed to oil or grease.
  5. Budget36
    Budget36
    I don’t run hub caps, wouldn’t be able to show off my pin striped lug nuts;)
    loudbang and partsdawg like this.
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you're really bored , you could paint the inside of your brake drums as well ,or you oil pan , the possibilities are endless !:D
    partsdawg, ClayMart, loudbang and 2 others like this.
  7. rockable
    rockable
    65 replies on whether to paint the inside of a bellhousing? Boys, y'all need something to do.
    ClayMart, jaw22w, Tman and 4 others like this.
  8. atch
    atch
    Folks,
    I didn't start this because I'm trying to build a show car. I started it to see if there is an advantage or drawback to paint on the inside of a bellhousing. STRICTLY what's good or bad regarding painting it. Will it help or harm anything?
    I'm sorry if I've wasted your time.
    clem, VANDENPLAS and loudbang like this.
  9. 57tailgater
    57tailgater
    from Georgia
    I'd use a lighter color of paint so if you did need to take a peek inside from underneath you will have some contrast and not everything will look black.
    Ecc412 and loudbang like this.
  10. spanners
    spanners
    You didn't waste our time. We used the thread as amusement in these bleak, sometimes serious times. My apologies.
    2OLD2FAST, VANDENPLAS and loudbang like this.
  11. Painting the inside of your bell housing ?!?!
    Be prepared!!!
    verno30, Greenblade, alanp561 and 4 others like this.
  12. Happydaze
    Happydaze
    Decoupage featuring era correct porn?
    Chris
    SS327, alanp561, Tman and 1 other person like this.
  13. LAROKE
    LAROKE
    I've used the Glyptal paint on my nailhead build for no other reason then that I like the way it looks.
  14. atch
    atch
    By the way, I appreciate everyone who gave a serious answer. I have now painted the inside white. After I put a second coat on it I will post pictures
  15. POR15 with a brush and it'll last longer than we all will.
  16. Waiting for the pics!
  17. atch
    atch
    Ok. I wasn't nearly as careful with the inside as I was with the outside.
    Now to go take the T-400 off of the 425 and start putting this stuff on.
  18. 19Fordy
    19Fordy
    Speaking of painted parts:[
    ATTACH=full]5284349[/ATTACH]
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    SMH :rolleyes:
  20. clem
    clem
    I got a rebuilt ‘39 box that was painted on the inside, - I thought that if the guy was that pedantic to paint the inside, that he probably took care with the rebuild. - runs beautifully……
    actually, atch - that came out really good….
    After seeing that I would probably go to the trouble of painting the next one also. Just seems more finished.
    (And it helps improve your painting skills).
    Desoto291Hemi likes this.
  21. Stan Back
    Stan Back
    What's the difference between the same year Town Car and the Towne Car?
    firstinsteele likes this.
  22. 19Fordy
    19Fordy
    Nothing, except an historical lesson in linguistics.
    Towne, an archaic spelling of the word town, is a surname, and may refer to: Benjamin Towne publisher of the first American daily newspaper, ...
  23. loudbang
    Got you a "Moon Pie" now. :rolleyes:
    427 sleeper likes this.
  24. I like that, atch. Wish I had done the same. The engine, too. Well done.
    Ben
  25. sunbeam
    sunbeam
    Lakewood and paint are they dipped?
  26. A padded vinyl roof with opera windows. And maybe a set of Vogue Tires. (mayonnaise and mustard)
    Stan Back likes this.
  27. Deuces
    Deuces
    Some HI-TEMP VHT paint should do the trick.... Any color you want!.....:cool:
  28. alanp561
    alanp561
    There are some who would find the combination of "Seafoam Green" and "Carmine Red" off-putting but I find it absolutely delightful, don'tcha know?. ;)
    LAROKE and Desoto291Hemi like this.
  29. cfmvw
    cfmvw
    Write yourself a note in there and date it! Done that with some of my projects, kind of fun to come across it months or even years later. My uncle recently pulled the door panel out of his' 69 Z/28 and found a note he wrote over twenty years ago... brought back some memories for him.
    SS327, alanp561 and Stan Back like this.
  30. if I had a bellhousing that looked that nice, I wouldn't want to hide it on a build, I'd make a lamp out of it.
    427 sleeper, Stan Back and alanp561 like this.
