Technical Anyone have a part number for ignition switch with start that fits a Model A dash panel?
Discussion in 'Traditional Hot Rods' started by banjorear, Jan 9, 2022.
  1. banjorear
    banjorear
    Posting to see if anyone has a part number or has ideas for a "modern" ignition switch (Off, assessory, start) that will fit in a stock Model A dash panel. The ones I got are too large and don't fit in the gas tank cavity. I'm using the cowl tank so cutting the tank is not an option.
    If there aren't any available, I'm considering using a momentary switch under the seat riser to use as the start function.
    Thanks,
  2. I have been into Model A's since 1962 and never seen what you are looking for.
    Charlie Stephens
  3. banjorear
    banjorear
    Thank you, Charlie
  4. denis4x4
    denis4x4
    from Colorado
    Got this one at O’Rielly’s years ago
    dana barlow likes this.
  5. patterg2003
    patterg2003
  6. banjorear
    banjorear
    Denis,
    Thank you. I think Cole Herse (sp?) may have one that will fit. I didn't think to go to a parts store to look.
    Patterg2003, I saw those this AM. I'm going to call because I want one that has start and then returns to ignition position.
  7. gary macdonald
    gary macdonald
    Does yours have crank in the key or you still use the floor to crank ?
  8. denis4x4
    denis4x4
    from Colorado
    I use an old school floor button…
  9. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    I use a fairly stock looking "A" dash in my 28A hotrod..
    To get the room I needed,for a number of things,I gutted the inside of gas tank.
    Also gutted out the back behind center "A"dash.
  10. I'm guessing it's a part # 8675-309 by your picture......
  11. Look up one for marine use.
    Don't know if these are shallow enough.
    Cole Hersee 4 position with key:
    Acc 10a
    Ign 10a
    Start 5a
    956-4100 4 blade terminals 1"- 24 bushing
    956-4104 4 screw terminal 1"-24 bushing
    956-4154 5 screw terminal 3/4"-24 bushing with ground terminal
    956-4304 4 screw terminal 3/4"-24 bushing
    956-4311 4 blade terminal 3/4"-24 bushing
    956-4704 4 screw terminal 7/8"-24 bushing
    HD
    Acc 20a
    Ign 20a
    Start 10a
    956-4138 4 blade terminal 1"-24 bushing
  12. I'm going with a keyed on/off switch with a start button either on the dash or on the dash/vent panel.
    Here's my friends '30:
  13. banjorear
    banjorear
    Ahhh, I like the push button idea. Thanks!
