Technical Spring over
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Jan 2, 2022.
  1. oliver westlund
    oliver westlund
    Okay ive searched but probably havnt used the right words...can i convert a 46 front i beam to spring over to use on an a frame? Cam i retain the 46 wishbone in foing so?
  2. Blues4U
    Blues4U
    from So Cal
    Yes, you can convert the I-beam axle to spring over, it doesn't matter to the axle if the spring is in front, over, or in back. And I have seen guys on here use the 46 wishbones by cutting the front mount off and smoothing the wishbone.
  3. 31Apickup
    31Apickup
    It will require a custom width spring.
  4. oliver westlund
    oliver westlund
    Seemed like all there was to it but wasnt sure
    Lloyd's paint & glass likes this.
  5. alchemy
    alchemy
    Or you could get the right width axle that uses common springs (28-36), and use the 46 wishbones and spindle stuff on it. Then there are a lot more variety of aftermarket springs to choose from.
    oliver westlund likes this.
  6. dwollam
    dwollam
    Oliver, my '29 Sedan avatar has a '40 front axle and split '40 wishbones with the '40 forward spring perches cut off and a custom length (from 1958) spring over the axle and perches.
    Dave
  7. Cut the front spring perches off the wishbone and put the perch bolts in with the shackle boss integrated.
  8. oliver westlund
    oliver westlund
    Hows the width compare dave?
  9. oliver westlund
    oliver westlund
    Perfect, already had a set of polished stainless bookmarked!
  10. oliver westlund
    oliver westlund
    I dont understand the width claims? 1/8"?? Is that it? Screenshot_20220102-195727_Chrome.jpg
    alanp561 likes this.
  11. rdscotty
    rdscotty
    from red deer
    Spring width
  12. oliver westlund
    oliver westlund
    I worded it poorly, i meant i dont understand why folks talk about how much wider these axle setups are...looks to be a 1/8" difference
  13. adam401
    adam401
    The 48 axle is like 1.5 or 2" wider. A 28-34 main leaf wont work. That late front-end stuff can be made to work but it looks pretty clunky. Ive tried making those wishbones work but with that bend they get looking crazy.
    As far as using a spring in front wishbone and modifying it for spring over, yes you can. I just put an axle together for my 34 and used a cut up 40 wishbone. Its not great (im not in love with the perch bolt boss area) but with the long spring perches it works.
    An undropped axle like a 33-36 is pretty easy to put your hands on. In my opinion they look the best but hey who am I
    hotrodjack33 and oliver westlund like this.
  14. twenty8
    twenty8
    Most of the "wider" talk is related to the spring perch dimension. This is the bit where it will affect the whole installation setup, and where a little experience (or guidance) can save both dollars and heartache.
    The small difference in the king pin dimension can be easily accommodated with wheel offset (although 1/16" each side can be ignored). Be especially aware of the '37-'41 axle regarding this. Notice that it is quite a bit shorter. It can still be overcome with 1" more negative wheel offset per side.
  15. oliver westlund
    oliver westlund
    I kind of think the bent wishbone looks cool... just wish i could find a pic of the 46 front on an a frame Screenshot_20220103-150949_Chrome.jpg
  16. oliver westlund
    oliver westlund
    Im trying to run wide 5 wheels on this, already have em. I think the adapters are only 1/8 thick though...will be fenderless. The few appeals the the 46 axle is, i have it, i have the matching rear so the width should match, it has like 2 inches of drop over the model a axle so that plus a reverse eye and losing a leaf or 2 should get me as low as im looking for (i think) its tough because i cant find a ton of pics or documentation on it amd mayne thats for good reason...i HAVE foumd pics of 50s and 60s built rods with this front and rear but those images were blurry and not very helpful for my questions besides validating that it was in fact done enough for surviving examples to be around
  17. twenty8
    twenty8
    @oliver westlund , this is from another thread.............
    You would need to lengthen your frame, or move the front crossmember forward in the frame to keep the model A correct wheelbase.
    Really though, your best bet is a Model A axle in the Model A frame. Get in touch with some axle drop guys and see if you can use the '46 axle as an exchange core for a dropped A axle. Using stuff just because you already have it can be a sure-fire way to sabotage your own project.
  18. You clearly don't know what I did or why. My build was planned out start to finish to make it exactly what it is. I do believe in its original post I explained everything.
    46international and Blues4U like this.
  19. twenty8
    twenty8
    Deep breaths man. I think you have mis-understood my post. I was showing your pic as the right way to use a later axle and keep it 'spring in front'.
    I still think the OP should stick with a Model A axle for his build though. If he is having to ask these questions, he should maybe keep the build relatively straight forward.......... (No offence intended.)
  21. Sorry about that Twenty8, my oven timer was going off and I didn't want my dinner burnt up again. I was going to say you pinned it right in that you must move the crossmember as well as the late front spring is wider than the A spring. There's more to it than just swapping it in place.
    However I didn't know exactly what you were getting at. No offence taken. I do try to fully explain what or how I do things when I post them up myself. I should not have hit Post when I did.
  22. twenty8
    twenty8
    All good here at my end...:) You enjoy that dinner.........
    Pist-n-Broke likes this.
  23. twenty8
    twenty8
    Blues4U and oliver westlund like this.
  24. Kool, that post of mine kind of spells it all out. Here's a photo that shows the verbal description of all the pieces I was talking about. I've posted it up an unknown number of times. If you think doing this job is out of your wheelhouse stick with all Model A parts. That way everything just goes where it belongs.
    adam401, oliver westlund and twenty8 like this.
  25. oliver westlund
    oliver westlund
  26. oliver westlund
    oliver westlund
    I read that post, i think ive read all applicable posts, just wasnt finding enough info to satisfy me. Im not sure why it would be out of my wheelhouse to simply get a longer spring and switch the perch setup to spring over? Doesnt seem that complicated... just need to poke at it and look at it and weigh out the options, my roadster is being built out of 6 cars and 3 manufacturers, i dont know everything but i can get by, especially with great help on here
  27. twenty8
    twenty8
    That is not what @Pist-n-Broke did with his build. He used a later axle but kept it spring in front. A bit more complicated.
  28. oliver westlund
    oliver westlund
