Hot Rods Sb chevy id
Discussion in 'The Hokey Ass Message Board' started by johnfin, Jan 2, 2022.
  1. johnfin
    johnfin
    from auburndale
    I have a block, 3970010, date e205 with a smooth right front pad. Is this because all replacement engines are blank? It also has the plug in the front above the cam. I read all 4 bolt engines have these. Iam guessing its a 1975.
  2. Budget36
    Budget36
    Can’t help on an ID, but I’d guess the block has been decked.
  3. Most 010 blocks was 350's... 2 and 4 bolt mains.
    And guessing correct probably a 1975
  4. squirrel
    May 20, 1975. The odds are good it's a 4 bolt main, but not 100%. For most applications, it does not matter. The block was almost certainly decked, you can tell by the surface finish--they were broached at the factory, you won't see that finish from any resurfacing machine that you'll find in machine shop. A belt sander will come closest.
  5. johnfin
    johnfin
    from auburndale
    The front pad is smooth as a babys butt. Decking would change the intake and pushrod geometry, right? How does the intake fit if the block is milled?
  6. I wouldn't think they'd deck it so much that it would interfere with head/ intake fitment, but I guess you never know. Probably just enough to zero deck height the pistons.
    olscrounger likes this.
  7. Black Panther
    Black Panther
    from SoCal
    In 1975 and generally true for the 010 blocks from the 70s...4 bolt main blocks were used in L82 Corvette...3/4 ton and heavier trucks and probably 4x4 applications. I'd say the odds of it being a 4 bolt block are approximately 5%-10% since the vast majority of Impalas..Novas..Camaro..vans..just about everything else using an 010 block in 1975 was a 2 bolt main..
    Deuces likes this.
  8. johnfin
    johnfin
    from auburndale
    Guy says plug up front by cam = 4 bolt main
  9. tomcat11
    tomcat11
    That's B.S.
    H380, connielu, Desoto291Hemi and 4 others like this.
  10. squirrel
    yeah, but....I'd say 90% of the mid-late 70s 350s that are still around were installed in trucks, and almost all of them were 4 bolt mains. So the odds of it being a 4 bolt are still really high. And from what I've seen, the generic 2 bolt 350s used in cars in the early 70s were mostly all 014 blocks.
    I recall seeing one 2 bolt 010, and a whole bunch of 4 bolts.
    427 sleeper likes this.
  11. johnfin
    johnfin
    from auburndale
    Are these the L82 pistons or L42 pistons. To me they are flattop with valve reliefs, some may say they are dished.
    Deuces likes this.
  12. Fordors
    Fordors
    This is an OEM L82 forged piston, with the long valve relief.
    Deuces and 47chevycoupe like this.
  13. gimpyshotrods
    gimpyshotrods
    The number of main cap retention bolts is a finishing process, meaning that it can be applied to any block.
    All 010 means is a casting designed to be finished with 4-in bores.
  14. gimpyshotrods
    gimpyshotrods
    Nope. I have worked on tons of 2-bolt main blocks with that plug.
    The only reliable way to determine how many bolts hold down the main caps is to pull the oil pan off the engine and count for yourself.
  15. squirrel
    yup, and it still doesn't matter in 95% of them...
    Deuces and Truckdoctor Andy like this.
  16. gimpyshotrods
    gimpyshotrods
    I have seen a whole mess of blocks that let go on the bottom end. On quite a few of them the split was in the web, and went right through an, or several, outboard cap hole bores.
  17. squirrel
    so they would have been better off with 2 bolt blocks....
    I guess my buddies don't go that fast. The only problem I've seen with a 4 bolt was in a work truck, never been apart, one of the outboard bolts was laying in the pan. Didn't hurt anything.
  18. gimpyshotrods
    gimpyshotrods
    It is certainly a matter for debate. I would like to get access to one that had such a failure for analysis.
    It would need to be determined if the damage would have happened either way, and just happened to cross that bolt hole, or the web was weakened by drilling a hole in it.
    The few that I have seen had split out right down the bolts.
    This is OEM Iron stuff we're talking about, not aftermarket race stuff, placed under extreme stress.
    I put a stud girdle over the caps on my block, because I did not want to run this test live.
    Deuces and 427 sleeper like this.
  19. squirrel
    I skipped right over small blocks when I was young, started with big blocks, that have really beefy main webs. I guess I missed out on all the fun.
    4274SPEED and Deuces like this.
  20. gimpyshotrods
    gimpyshotrods
    Yeah, there is a whole lot more metal there on a big block.
    Deuces likes this.
  21. It would mess with intake fitment for sure, you then have to machine the mating surfaces on the intake to fit properly, or deck the china walls to compensate. You would need shorter pushrods, but it shouldnt mess with the geometry in terms of the angles due to engine being a 90 degree design.
    Deuces likes this.
  22. Replacment blocks had numbers on front pad as well as usually being with the letter code "CE"
    Deuces likes this.
  23. johnfin
    johnfin
    from auburndale
    What if it was decked less then .010, would the intake and pushrods still need work? My intake does not look like it was reworked.
  24. squirrel
    it's probably fine. Those blocks were never square from the factory, any time you want to build one well, you need to machine the deck surfaces, but usually not enough to screw up the intake fit.
    Deuces, Hombre, Desoto291Hemi and 2 others like this.
  25. johnfin
    johnfin
    from auburndale
    I put a scope thru the front timing chain area and it looks like a 4 bolt main engine. Let me know what you guys think. I could not get a good pic going into the oil plug.
    Deuces and squirrel like this.
  26. gimpyshotrods
    gimpyshotrods
    That certainly appears to be the case.
    Deuces likes this.
  27. wheeldog57
    wheeldog57
    Nice ultrasound, is it a boy or a girl?
  28. gimpyshotrods
    gimpyshotrods
    Uh, it does show two nuts....
  29. gimpyshotrods
    gimpyshotrods
    Intake, or the end-seal areas of the block would need a tuneup. I prefer to do it all on the block.
    Nothing need be done with the pushrods. The angle change is nearly negated by readjusting the rocker arms. What little is left is negligible.
  30. Jim,
    That is an excellent pic in post #4 you posted .
    I wonder how many numbers matching blocks in extremely expensive cars have those same inline marks on the decks ?
    Just makes you wonder some time ,,,or at least it does me .
    Tommy
