Projects Pulled Dad's 37 pickup out of the barn
Discussion in 'The Hokey Ass Message Board' started by Poppinjohnnies, Oct 21, 2019.
  1. Tim
    Tim
    from KCMO
    Wow great project!
    Stogy and loudbang like this.
  2. Roothawg
    Roothawg
    How are the cab mounting wood pieces?
    loudbang, Stogy and dirty old man like this.
  3. Poppinjohnnies
    Poppinjohnnies
    A little update. Fenders and running boards removed. Lots of rusty bolts that haven’t been off the truck since it was rolling down the Ford assembly line. Next is the steering column/ box and then the cab.
  4. Poppinjohnnies
    Poppinjohnnies
    Dad got it stripped down to a rolling frame. We’ll peel it naked and then it’s off to the blaster to get cleaned up and a fresh powder coat. D7786ACE-1F71-4D3A-8857-4B8C6A4E69EA.jpeg
  5. Poppinjohnnies
    Poppinjohnnies
    Dad and I ended up in the Feb. 2022 Hot Rod with his '37 Ford pickup! That was an unexpected surprise. The truck is in an earlier thread of mine. Dad has it stripped down to the bare frame, and it's heading to the powder coater next month. I drug a few dead flathead V-8s to my shop yesterday to see if I could salvage some parts. It looks like we do have a useable Merc crank! I am in need of some opinions / advice. We have a couple of (what appears to be) good '37 - '38 blocks, and I brought home a few late model engines to disassemble and inspect. What block would be a better one to run in this, old style or later?
    lothiandon1940 and catdad49 like this.
  6. Run the later block...just my 2 cents ! keep the updates coming...
  7. Poppinjohnnies
    Poppinjohnnies
    It’s been a while, but here’s an update. The truck is stripped to the bones, and everything was blasted and primed. I tore apart a couple of spare flatheads looking for useable parts. One was a Merc engine with a hole in the side of the pan from a thrown rod. The block was junk, but luckily the crank looks pretty good. There’s a local older gentleman with a large cache of parts who has offered some to me, so I’m hoping that there will be some good stuff there that will help us out.
    oliver westlund and simplestone like this.
  8. Poppinjohnnies
    Poppinjohnnies
    The wood was in excellent condition. We plan to reuse all of it.
    lothiandon1940 likes this.
  9. Poppinjohnnies
    Poppinjohnnies
    Here’s some more pictures. The grille was missing a bar. Dad made one out of a piece of scrap. I thought he did a good job. Next is the frame and suspension rebuild. The engine will follow that. Dad bought a rebuilt transmission from a guy a while back, so that’s covered.
  10. Cgrgrspt10
    Cgrgrspt10
    Lookin good!
    Poppinjohnnies likes this.
  11. 1952henry
    1952henry
    Thanks for updates.
  12. Poppinjohnnies
    Poppinjohnnies
    Haven’t had an update for a while. The frame is painted, and dad is working on the front and rear suspension now. Here is a picture of the bushing that was a real booger to remove. One step at a time…
  13. Poppinjohnnies
    Poppinjohnnies
    Say, we need to buy or borrow a king pin reamer for this truck. We'll probably need to do the same thing to a '36 Ford pickup as well (future project). What's the best (and cheapest) source for a reamer?
  14. back up to the top
