Projects 58 Apache project
Discussion in 'Traditional Hot Rods' started by Sk1989, Dec 20, 2021.
  1. Sk1989
    Sk1989
    This is how I bought my 58 Apache
    BBCEC61E-DFBC-4DD3-8F3A-5D7C1DF4202A.jpeg 72882F64-DD92-47DF-B9E5-6BA166E2912D.jpeg
    the engine and gearbox were not mounted in the car there was no drive shaft and no exhaust, when I had all that installed I decided to paint the back of the chassis and put some new wood in the bed of the truck and drive it first.
    04F41584-CAE2-42C8-B987-0CA16AB4AEA7.jpeg E4AE90C4-6B36-48F8-9F06-2817E89D4B27.jpeg 19C640B0-4573-4AD2-A926-3C2C9CFC1B96.jpeg BB244DE4-8E62-4447-AEBF-3E886C033E76.jpeg 76A274B9-DF4D-41BD-82AB-795A8F7C9743.jpeg 8A8EE894-BFE4-41CD-B4CB-BD16AFB53C3E.jpeg
    after a few months I decided to replace the flexplate as the teeth were very worn. and because I thought the engine could use some paint I took the engine out and sprayed it in 2k hugger orange and put the engine back after the front of the chassis was also painted
    91963B2F-11F0-4C70-80AE-3EC134AC8B4A.jpeg DAC3DD82-9143-4DA3-A9DE-1AADEF46EF68.jpeg 84FF1765-FF84-4D04-9E72-0C860F65FB4C.jpeg
    in the first instance I would put the cabin and front clip back without spraying,at first I would put the cab and front clip back without spraying, but I changed my mind.I started by removing the paint from the cab.
    the car was rock solid but this was going to take too much time so i decided to take the car to the sandblaster.
    when I got the apache back from the sandblaster there were a few small spots of rust that I ground out and welded in new pieces
    1EA611D8-E514-42BA-B55B-EE14641789A4.jpeg 4BB9CDE6-1721-41E9-87D9-36BEBFBF1053.jpeg
    when that was done I could start sanding the epoxy primer
    first I block sanded the car, then a fuller primer was applied
    after all that sanding we could finally apply the color
    6252BF8C-FA96-4B89-B392-256286DDB322.jpeg 6E848E44-AF94-4437-9036-58328DB8D707.jpeg F77ADA02-6082-436B-938A-299061526C57.jpeg 58B6613C-21D5-40B1-AC13-3FAB04BFE0D2.jpeg 6E1389B3-D86E-4F46-BBAD-6FA5F00908E9.jpeg 7016B4D2-F177-4446-BBE3-8685151719B5.jpeg
    i
    Budget36, Chucky, catdad49 and 23 others like this.
  2. RMONTY
    RMONTY
    Damn! All in one post! Impressive! I like your truck!
    41 GMC K-18 and Sk1989 like this.
  3. Sk1989
    Sk1989
  4. Nice..your color choices work well together.
    Sk1989 likes this.
  5. Nice job
    Sk1989 likes this.
  6. 41rodderz
    41rodderz
    from Oregon
    Whew …. that looked easy . I. didn’t even break a sweat during the picture sequence. :D Good looking truck.
  7. Sk1989
    Sk1989
    I have shortened the bank's backrest about 2.5 inches so that it does not protrude above the edge of the rear window 9A5B84D0-DF92-43F1-83C6-7C6BB5A5E03A.jpeg 566F1CA9-E107-45FE-B932-2B52A61E14EA.jpeg
  8. Nice touch adjusting the height of the back of the bench seat… never really liked seeing the seat in back window when admiring my truck
    Sk1989 likes this.
  9. [​IMG]
    Very nice!!!
    Sk1989 likes this.
  10. tjet
    tjet
    1. Early Hemi Tech
    good burnout
    Sk1989 likes this.
  11. Sk1989
    Sk1989
    thank you I have removed one and a quarter inch from the top part and one and a quarter from the bent part and have removed the springs, this also brings you a little lower in the car
  12. Sk1989
    Sk1989
    I mounted the steering wheel today, DC44A133-74BA-41C8-8C5F-187F63CF2387.jpeg 5E34F864-901B-4E29-B3F6-1654D8BDF214.jpeg I had already assembled it before but I was not satisfied with the outcome. I have to say that it has become very beautiful now
  13. perk03
    perk03
    from VA
    great looking truck and project. Have you given any thought to moving the gas tank out of the cab to under the bed. I did this on my 55 cause the gas fumes were terrible when the tank was full. Also seems bit safer ...but I too like your color combination..:)
    Tutashen and Sk1989 like this.
  14. Sk1989
    Sk1989
  15. Sk1989
    Sk1989
    I have to say that I have no bother from gas fumes after I have replaced the hoses and gaskets on the tank.
    But that does not mean that there are no plans for moving the tank in the future, the extra space in the cab is often handy and a little extra weight on the rear wheels will not hurt either
    I would like to leave the tank cap at the current location, so if someone has already done tips here are very welcome.
    catdad49 and Tutashen like this.
  16. ROADSTER1927
    ROADSTER1927
    Looks Great Merry Christmas!
    Sk1989 likes this.
  17. xhotrodder
    xhotrodder
    You are one lucky person. The big back window 58-59's are harder to find & bring the big bucks in America. Enjoy your truck.
    Sk1989 likes this.
  18. 4 pedals
    4 pedals
    from Nor Cal
    Makes me miss the 55 and 57 I have had. Nice looking truck!
    Devin
    Sk1989 likes this.
  19. Tutashen
    Tutashen
    I'm going to pull the cab off my truck this summer figured it would take a month atleast after seeing this it's going to be done while i'm eating lunch Whew indeed :)
    Sk1989 likes this.
  20. Tutashen
    Tutashen
    yeppers i would leave the cap there to for looks an put a fuel cell under the box with hidden cap when you get around to it,the space behind the seat is great to hold a toolbox,oil,antifreeze, an for me living up north an old winter coat an blanket,tacklebox, fishing rod cause if your stuck might as well go fishing but my truck is daily driver yours looks scared to park at grocery store imho lol Great Job
  21. Sk1989
    Sk1989
    that's how this project started 6 months ago my intention was to replace the flexplate and in the meantime it has become a full restoration
  22. Sk1989
    Sk1989
    I'm thinking of connecting a tube to the original ful cap and connect it to the tank under the bed.That's the drawback I ran into,I'll miss using the car daily and being able to park wherever I want or not have to worry about damaging the paint while working on the truck.I guess I just need a new project car to drive daily;)
  23. I have always liked and appreciated sharp trucks like yours…just afraid I wouldn’t use it as a truck because it’s so nice!
    Sk1989 likes this.
  24. Sk1989
    Sk1989
    57AD0690-3F84-4C38-B542-07B6D4C09C05.jpeg 218F6140-8B31-4589-8468-8E6200CECE10.jpeg Today I was lowering the front of my truck. The front axle was placed quickly but when I wanted to assemble the Kingpin I found out that there was a difference in the front axles.
    When I want to install the Kingpin, there was approximately one centimeter space between (0.39. inch) between the front axle and the KingPin. Have several different axes used between 1955 and 1959?
    guthriesmith likes this.
  25. The only difference I know of from 55-59 is between 1/2 ton and 3/4 ton. Here is more info.
    Edit: After looking closer at the link I sent below, I just saw that there are two different king pin bosses (2-1/8” or 2-1/2”) those years which is exactly the difference you are seeing.
    https://droppedaxles.com/chevy-dropped-axles-0
    Torkwrench and Desoto291Hemi like this.
  26. Sk1989
    Sk1989
    Thank you for your help.There are apparently 2 sizes of front axle
    Only now is how it should be solved. Are there also 2 sizes Kingpin? Or should there be a 1/2 ball bearing between instead of the trust bearing that are now between them?
  27. Pretty sure the bearing is used on the one with the shorter boss. I would have to either ask Sid or try to look back through pics of when I put a dropped axle under my 58. I am pretty sure mine had the bearings which would be needed to take up the extra gap assuming there is only one type of spindle.
    Sk1989 likes this.
  28. I asked Sid and sounds like spindles and kingpins are the same for both axles. The only difference is between a bearing or thrust washer. He mentioned that many times, the kingpins will come with a 3/8” spacer to take up the slack so that the thrust washers can be used with the shorter boss even.
    Sk1989 likes this.
  29. Sk1989
    Sk1989
    thanks for your effort I'll see if I can get a set of kingpins with spacer or bearings:cool:
    catdad49 and guthriesmith like this.
