Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. saltflats
    saltflats
    from Missouri
    What valve seat angle are you running, can you change that from stock?
    Stogy and loudbang like this.
  2. I don't see why not, nothing in the rule book.
  3. I use typical performance angles 30 45 60
    But I have tried 30 45 70 with some upper lift flow gain but a loss of low lift flow.
    But bowl and runner shapes I will not share at this time. Sorry guys
  4. Engine teardown today and inspection.
    Everything looked very good except one rod bearing that had a tiny scar in it. It looked OK and was in tollarence but are getting replaced with new ones. I will loosen the fit up to .0023 on the rods. The mains were perfect and will be used again. As well as the rings, the 20211221_152344.jpg 20211221_161815.jpg 20211221_161830.jpg pistons look very good and will be reused.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Have you talked to your crank machinist about counterweight knife-edging?
    Deuces and loudbang like this.
  6. I have but this crank doesn't have enough counter weight as it is and had to add heavy metal to get it in balance so we don't have that option. Balance in this engine is so critical with only 4 main bearings.
    Deuces, Stogy, chryslerfan55 and 2 others like this.
  7. saltflats
    saltflats
    from Missouri
    Any carbon pattern on the piston tops to give any clues for combustion chamber mods?
    You have to excuse me, just throwing out my crazy ideas.
  8. I lightly modified the chambers on this head from the head we ran before 2021 speed week of 116 mph This was a big performance gain over 2020 speed week where we ran 123 in 2021.
    I really don't think there is much left in the head to gain other than milling it .030 more and upping the the compression some. Looking at a possable cam
    change after discussions with Cam Craft tech depth in North Carolina.
    Just not sure at this time.
    But need more power for sure
    Deuces, chryslerfan55, Stogy and 2 others like this.
  9. Stan Back
    Stan Back
    "2021 speed week of 116 mph This was a big performance gain over 2020 speed week where we ran 123 in 2021." Huh???
    Dino 64 likes this.
  10. 2020 we ran 116 and change... in 2021 we ran 123 mph 7 mph faster.
  11. Checking out the crank today and a good cleaning after polishing up the journals 20211231_143601.jpg
    Deuces, D-Russ, chryslerfan55 and 7 others like this.
  12. Getting the masters magic touch
    Deuces, D-Russ, Stogy and 4 others like this.
  14. I finally received the Rod and Main bearings and shipped them off to Calico Coatings. They promised a 5 day turnaround.
    I'm working on a possable cam change once I do some Dyno simulations with some new opening and closing events. More to come so stay tuned
  15. 51504bat
    51504bat
    Looking forward to them. Can't wait.
  16. Drive shaft clearance at crosmember forward of the rear axel 20220107_164057.jpg
  17. SEAAIRE354
    SEAAIRE354
    I was going to bring up the knife edging on the counter weighs but French town flyer beat me to it. Do you run a crank scraper or windage tray? Don’t see any hardware to support that.
    chryslerfan55, Stogy and loudbang like this.
  18. Not much room in the oil pan on this engine and the crank is up inside the block making it difficult to do. the cam is on the side where a scraper would be. That would not alow oil to wet the cam lobes. So no scraper, the pan is less than 2 inches from the crank in the rear and 3/8 " in the front no room for a windage tray..
  19. jimmy six
    jimmy six
    MPH get tougher to find as you move up in speed. Another 7 will be real tough. The new chassis work will definitely help.
  20. saltflats
    saltflats
    from Missouri
    He is running a dry sump, how much help would knife edge or a scraper be?
    loudbang and Stogy like this.
  21. This class for a Ford has a big disadvantage as the cu. In. Limit leaves us short by 50 Cubic inches. And a very bad AERO BRICK.
    So this is and has been a
    World Class Challange
    We at this point are the fastest XO/PP Ford inline six to challenge the record in the class.
    And that alone is a notable accomplishment but we want the record more than anything.
    If we had more cu. in.'s the challenge would be easier
    To make the H.P. needed to succeed.
    Still some small things that will help us get there and we will keep digging deaper.....never give up!
  22. saltflats
    saltflats
    from Missouri
    I say you and your time is doing a great job.
    Old architect is not the easy way by any means. Keep digging.
    Stogy, chryslerfan55 and loudbang like this.
  23. That's pretty cool, I didn't realize that.
    Stogy, loudbang and chryslerfan55 like this.
  24. @D-Russ , I’m beginning to think you feel the need, the need, for speed.
  25. 20220114_175304.jpg 20220114_175225.jpg I received the engine bearings back from Calico Coatings today now I can button up the short block
  26. pretty swanky, may I ask what that costs? You can PM in private if needed.
  27. Both sets $105.00 including shipping but worth every penny
  28. that is not bad at all! Thanks for sharing
  29. 6sally6
    6sally6
    I hate askingdumb questions but....I guess you have off-set ground the crank and bored it to the max?!
    Still 50 short..
    6sally6
  30. I still have another over bore left and because these 262 engines are so rare and hard to find. I don't want to go to full on kill just yet. Could prolly get 6 more cu. In . If I maxed everything out. It will be the last resort.
