Projects 55 210 Wagon Progress
Discussion in 'The Hokey Ass Message Board' started by MP&C, Mar 24, 2013.
  1. MP&C
    MP&C
    Now for our bottom plate for the air cleaner.. In order to keep the filter located properly (keep it from moving around) we decided to add a bead to the bottom of the plate.
    Then the plate is trimmed to a circle, and the thumbnail dies in the Lennox used to start the shrinking process around the edge.
    We then jumped on the Erco kick shrinker to flatten the uneven surface..
    And repeat. Repeatedly. We have two or three more rounds to go and we can start tipping and stretching.
  2. All work, Kramer approved.:D
    alfin32, Stogy, fauj and 6 others like this.
  3. MP&C
    MP&C
    Last night we changed out the thumbnail shrinking dies for linear stretch dies in the Lennox TE250 in order to tip the flange back horizontal again. We have a backstop / fence that had been notched for tooling and this did a nice job of getting the flange depth consistent.
    As this gets bolted to our linear slide and we'll need that to remain stationary, some Cerutti built clamp blocks are added.
    Linear stretch dies in action:
    Next, we had been having issue with the Skat Blast cabinet, and given the sale going on this week at TP Tools, ordered a new high volume cabinet gun and nozzle, some high flow fittings, and while we're at it, how about some fresh glass..
    Amazing....we can see!
    But alas, all the new parts did not fix the losing media about 5-10 seconds in. So we figured this was a blockage with the suction tube, which requires removing the expanded metal deck inside. Which has sealant along front and rear edge. So a handy utility knife was employed, along with this fancy tool we had made up for removing tiles in raised flooring, as it did well in pulling up the expanded metal.
    The screen was tipped up out of the way and a large magnet holds it in place...
    Once we had access to the pickup tube, we noticed a hole in the inside corner that didn't belong.
    Once we removed the tube, we noticed it was more widespread...
    Well, I guess we have found the suction/media issue, and now have a used High flow gun/nozzle for sale. Luckily the sale is still going on, ordered the replacement tube last night..
    TFoch, fauj, brEad and 5 others like this.
  4. It is always something. I continue to really enjoy this build and appreciate all of your time and effort to share these pics and videos with us. I know that it is a lot of effort to spend which doesn’t actually get the car finished. Kudos to you!
    Stogy, safetythird, loudbang and 3 others like this.
  5. safetythird
    safetythird
    I appreciate it no end-I've learned a ton just from the photos, and am going to attempt to apply it to my current build.
  6. MP&C
    MP&C
    Thanks for taking time to comment guys!!
    Now to fold the outer perimeter of our air cleaner base. I thought of using a tipping wheel, but that appeared to be rather close for comfort. So a curved piece of bar stock in the scrap pile (resource inventory) was selected and a drum sander used to fine tune the radius to match our part.
    Then a hammer form was made to stretch and shape the "horn" of the base. Quite a bit of stretch needed but you don't know until you try...
    Video of hammer action:
    Alas, cracking occurred, so the horn was trimmed just down from the radius and a piece of 18ga was hemmed, rolled, and welded, to form a band. The band was tacked up for a test fit, we'll get it fully welded tomorrow and get all the parts bolted up with some rivnuts and press nuts..
    Yesterday we got our replacement tube from TP Tools for the Skat Blast 1536 cabinet. Can't remember the last time it worked like this, so I'd guess we've had a "leak" for a while now.
    And since we replaced the nozzle unnecessarily, we now have a good used media blast cabinet gun for sale. Has the High Volume power head (20-25 cfm required) and tungsten carbide nozzle, if anyone needs one. I think $50 plus shipping would be fair. No trigger, intended for use with foot pedal. For a hopper/suction machine, it does work nicely..
    D-Russ, Stogy, tb33anda3rd and 6 others like this.
  7. Always enjoy your updates. Even though I don't have any of the tools, (well any of the powered tools), you have, it gives me ideas on how to get some of my simple metal shaping done.
    Thanks!
    Stogy, loudbang, MP&C and 2 others like this.
  8. MP&C
    MP&C
    More travel for the day job, had to install a 24' video wall. Back in the shop finally, progress on the air cleaner continues.. We had some stainless mesh left over from our speaker grill fabrication that we plan on using to address air flow inside our pocket for the ignition coil.
    An 1-1/2" Rotacut is used to provide the hole in the pocket, two pilot holes spaced 1/2" apart will expand the hole for us.. The venturi effect inside the breather should promote air flow across the coil.
    Next, to hold the mesh in place some retaining rings will be needed. We'll use some MDF trimmed to size to fabricate these...
    Or the action version....
    The newly formed part has a tight hold on the hammer form, so much that we can clamp it in the vise, drill the two pilot holes to match the pocket, and drill out two 1-1/2" Rotacut holes without the part budging..
    The dynabride belt sander cleans up the points into flats, the side flanges are trimmed to size with a roloc sander, and then we can roll to fit the inside of the pocket.
    test fit....
    Holes are added for some 3/32 rivets to clear the mesh
    Aluminum pop rivets are used to get a better view of the final look before we blow it apart for priming..
    We will be using press nuts in the coil to ease the pain of assembly, and we also added some more shiny stuff on the front end..
    D-Russ, brEad, Stogy and 11 others like this.
  9. loudbang
    Is that the standard "Garage Fix" racer tape for a boo boo on your hand. :rolleyes:
    fauj, Stogy, kidcampbell71 and 3 others like this.
  10. MP&C
    MP&C
    The deburring tool doesn't care what you put in front of it. :D
    bobss396, fauj, belair and 6 others like this.
  11. manyolcars
    manyolcars
    this build has been going as long as Project Binky
    KandN Kustoms and '28phonebooth like this.
  12. Ok. And its bad *ss .. with or without, your binky. Go make poopy.
    SS327, RMONTY, tb33anda3rd and 3 others like this.
  13. rod1
    rod1
    With incredible results...Crawl back under your rock.
  14. MP&C
    MP&C
    But he does have a valid point. :)
    The pitfalls of a part time shop and a day job that sends me on far too much travel.
  15. Robert, when you reach the point of calling it done, will you or the owner planing on entering the car in any of the major shows? like the Detroit Autorama Riddler Award or great 8?
    The car has turned out as nice as any of pro built cars from the past. HRP
    loudbang, kidcampbell71 and Stogy like this.
  16. MP&C
    MP&C
    Danny, I’m fairly certain it will head to Tri-five nationals, Jalopyrama, and a few that are more local.
  17. rod1
    rod1
    An incredible job you have done, and to length that you have gone to show us how is much appreciated. Please keep it up.
  18. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Even though I shake my head at those that think showing off a crap rod, or a neglected Barn find or a car in bare metal for the sake of Look at Me! I almost feel bad that all this excellent fabrication and repair is being covered up by paint, upholstery and plating. Robert, it sounds like you know your way around a flat screen or two. So, I hope you will develop a slideshow display/presentation of some of the million or so pictures and the million or so of hours { probley not all billable! If they were, tell me your bookkeeper's name! lol} I have been following your progress for the better part of 20 years since the old tri five days. Always with growing respect and admiration of your talent's. Larry
  19. MP&C
    MP&C
    Thanks for all the comments guys!!
    Some equipment repairs were in order over the New Year's break, our tried and true Lathem time clock in the shop had given up the ghost. In speaking to Lathem, this model has been obsolete for some time and the only parts available are the print ribbon and a replacement motor. Doesn't help me with this little part...
    Quite used to this lack of availability in car parts, how hard can it be? A $1.99 package of music wire from Hobby Lobby and some round nose pliers, we are back in business.... Never underestimate what you can do with a pair of needle nose pliers ;)
    Next on the list, I had received a pair of Fairmount wire edge pliers for Christmas, which had quite a twist to the handles where it was difficult for the catch to swing over the adjacent handle:
    Since these aren't available for return at the local hardware store (obsolete), and also since they are drop forged, I decided to do some heating and twisting. The Meco torch was used to bring the handles to a light tan color.... and a twisting device employed with a bit of tension via ratchet strap as the handles cooled...
    ....and here's a video showing their use on a test sample. These do a nice job of locking the wire tight to the flange as you stake and wrap the wire..
    Finally, since the artist in the family had asked a few months ago, looking for a canvas to paint, I pointed her to the Lennox. Here is the layout on the one side in Sharpie in prep for painting..
    As far as the wagon, we are still here, back to one of the more boring stages..... applying epoxy primer and making black dust on the floor...
    And in the planning stage for one of the trim details, the owner had ordered a ball milled dash insert for the wagon many months ago, which was far too 1990's billet. So naturally I breathed a sigh of relief when it did not fit the dash contour. (go figure) I was leaning toward an engine turned panel as it is more of a hotrod flavor. Unfortunately, it is more of a TRADITIONAL hot rod flavor, and we were in the gray area there as well. So in the meantime, a buddy has a shop in Wilmington DE, and does absolutely fabulous detail work (had a hand in the Double Bubble wagon's fabrication), and has been using this ribbed stainless sheet for dash inserts and other details.. (his picture and work)
    This gives a nice classy and timeless look that is a better fit to the flavor of the car we have, so that is the direction we're headed... So to test a theory in adding a finished edge around the perimeter, we broke out the false wire edge Pullmax dies and installed them in the Lennox for a test run on some 19 gauge stainless. The "backstop" was setup to be just shy of a full wrap, which should give us a slight gap for the ribbed stainless to slide into. Our edge strips will be "outfitted" with some hidden press studs to hold it in place on the dash.
    A little bit of polishing and that may just work.....
    alfin32, brEad, tb33anda3rd and 7 others like this.
  20. Great save on the time clock, Robert. I bet Lathem would have preferred that you buy a new clock!:D
  21. Had the Fairmount pliers been damaged or were they just designed in that peculiar fashion?
    Algoma56, MP&C and loudbang like this.
  22. MP&C
    MP&C
    They were twisted enough that the retaining clip was difficult to get it to drop over the next handle. I would think it was many years of use/abuse that brought it to that condition, and not the original design. Or I just really F'd up an original tool. :p
  23. MP&C
    MP&C
    More blocking, then more epoxy...
    Another hurdle in the way of running our wiring under the dash, we need to address the defrost vents for the Vintage Air unit. What they send is cheesy at best, and given they only send two vents where Chevy installed 4, we're going to go another route..
    The factory piece does take up quite a bit of real estate, and now interferes with the raingear wiper system and the VA heater box.
    So all things considered, we plan on using the original vent top portion and adapt tubing in the equation to make use of a more flexible hose arrangement. The VA has two 2" outlets at the top for defrost, so we will use a 2" tube to feed the center two vents, and 1-1/4" tubes to feed to the outer vents.
    Missed some of the details with that one, a bit more for the center vent..
    Forming our transition from 2" to 1-1/4".....
    As the ports from the VA point almost straight up, the 2" tubes were welded at a slight incline to remove any sharp bends in the supply hose.
    .....as a follow-up, our local artist has been working on the other side of the Lennox..
    and we have been working with some local hippies to explore other shop shirt options.. This was done on the yellow shop shirt so naturally that base color limits what results you will get...
    alfin32, Bowtie Coupe, TFoch and 6 others like this.
  24. Excellent update, Robert. Can’t wait to see the final version of the local artist’s work!
  25. MP&C
    MP&C
    In adapting our defroster vents for the wagon, we needed to add a bead in the tubing to better retain the hose attached. The beading die we made for this purpose on the bead roller was too large to fit the 1-1/4" tube, so another tool is in order.. Our worn out Southbend was used to make the round profiles, with a step in the bottom die to act as a backstop for better consistency in bead placement.
    I don't have much in the form of hardened tool steel for making specialized cutters for the lathe, so I used a 3/4" square cutter from the Lennox to form the following for making the concave shape.. the male counterpart was done on the fly...
    The 4140 square stock was squared on both ends, then a relief added for our round profile to rest in.
    Our c-clamps had a VEE notch that would assist in keeping the round bits from moving, so that was used in lieu of a vise..
    The infinitely adjustable clamps worked well, the TIG was used to add a fusion weld around the perimeter (no filler rod)
    After welding, the assembly is heated to a straw color (pre-blue) and dipped in our official Mickey Thompson fluid container (transmission fluid) to harden things up a bit.
    Here are the dies in use, take note of what happens when you don't keep pressure against the backstop.... No harm no foul, a couple more passes cleans it right up...
    That should help to keep the hose in place...
  26. MP&C
    MP&C
    After a long hiatus of hanging TV's for the day job, so...where we had left off on the wagon, more blocking of primer, fabrication/modification of defroster vents, and wiring.. So a test fit of our fuse panel mounting plate (American Autowire) found that along with our parking brake pedal assembly location and the close proximity of the Raingear wiper motor, things were much too snug. So in looking at the room available under the dash, just to the right of the brake pedal looked promising but one of our newly formed defroster tubes interfered. This one hung down too low....
    And, in typical domino fashion, the fuse panel mounting plate would not work where it was not intended.
    We made a new bracket of 1/8" aluminum, and bent some mounting ears to be able to place it well above the accelerator linkage. We also designed it to use existing hardware to minimize any additional holes through the nicely painted firewall.
    Next, the interfering defrost duct was shortened to provide the needed clearance. Side note: Check out the HAZ difference between a TIG tack on tight fitting panels vs. having to add filler on a slight gap...
    Fitted before we do the final welding, this shows to leave us sufficient room...
    And now for the fun part....
  27. Go man go! :) HRP
    MP&C likes this.
  28. MP&C
    MP&C
    While we're getting prepared for wiring installation, the instrument cluster was dug out of its box to help us see where all the wiring was going. And there it was in all it's billet glory. This will kinda clash with the ribbed stainless trim we're using for the dash insert, so let's look at adding it to our gauge cluster as well...
    Where this gauge cluster was designed with a flush fit in mind, we need to be able to hide the cut edge of the ribbed stainless. So the holes were opened up slightly where the gauge could be installed from the front, and the bezel will now hide our cut edges..
    The stainless is in a rather raw form, and to give it more pizazz, perhaps some polishing is in order... So we used some Trizact products on the DA, and ended things on the buffer...
    Here's how it turned out...
    We also have some new indicator lights coming for the high beam and turn signals to get away from the tiny LED's that also scream billet.. The new lights should hopefully be here Saturday where we can get this modification wrapped up this weekend..
  29. rockable
    rockable
    Where did you get these?
  30. MP&C
    MP&C
    Alpine tech dot com.
    lothiandon1940 likes this.
