Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    The grocery getter
    winr, Just Gary, bchctybob and 20 others like this.
  2. Dave G in Gansevoort
    from Upstate NY
    Stogy, 31Apickup and loudbang like this.
  3. The 39 guy
    The 39 guy
    Looks great Paul! It is a real time piece! Looks like you just brought it out of long term storage. Since about 1958 maybe. It's just COOL!
    Stogy, loudbang and Paul like this.
  4. rod1
    rod1
    Man that's nice
    Stogy, Paul and loudbang like this.
  5. Paul
    Paul
    Editor
    I think I may have found the cause of uneven exhaust heat (and slight backfire at higher rpm).
    The heat riser tube in the exhaust crossover was burned/rusted through allowing fresh air to be drawn into the exhaust.
    I will be installing a manual choke so I just tapped and plugged both ends of the tube.
    It's all back together but of course it's raining again so test runs will have to wait.
    Atwater Mike, bchctybob, Tim and 9 others like this.
  6. Paul
    Paul
    Editor
    Another issue solved, something wrong with the charging system, generator was rebuilt a few years ago and run for a short time on the '27, then put on the shelf when I was lucky enough to score a chrome one, so I was pretty sure it was ok.
    Also fairly confident of my wiring schematic, but rechecked that anyway. All seems good.
    That left the regulator, it was an unknown I pulled from the shelf, used but visually looked ok, very clean under the cover and on the back. I put an NOS Badger chrome cover on it and crossed my fingers.
    Looked on line for a replacement and was surprised at the going prices.
    So I looked at it a little closer..
    The ground strap on the two mounting bolt end was missing, why I didn't catch that I don't know..
    As a temporary fix and check I pulled one of the rubber isolators and replaced it with washers.
    That did the trick, at idle with fuel pump and fan running the volt meter reads about 12.5, driving with headlights on it's that plus a bit.
    Drove around for a half hour or so and all seems good.
  7. 64 DODGE 440
    64 DODGE 440
    from so cal
    That car just screams essence of hotrod.
  8. Paul
    Paul
    Editor
    Got a pair of Studebaker hi low horns from a buddy yesterday, got them in and working today.
    Stude horns, F100 box, C10 column and Olds wheel, like a match made in heaven :)
    winr, Just Gary, bchctybob and 9 others like this.
  9. RodStRace
    RodStRace
    Yes, here is the snippet, but you really need to watch the entire movie, it's a classic!
    www.youtube.com/watch?v=tZrqC5LL_oo
    Paul, sounds like it needs some Mopar in the mix!
    bchctybob, loudbang and Stogy like this.
  10. Paul
    Paul
    Editor
    Not much of an update,
    I did straighten out the tail pipes though,
    welded in a section of bend right under the rear axle and ran the pipes parallel and level back to end about the same distance back as they were.
    I think that will do.
    I've run about a half tank through it on the road now, getting closer all the time to a decent tune.
    Still not ideal yet, starts decent, idles nice and good power but coming off idle isn't quite right, I need to bring the rpm up to pull away strong.
    Maybe it's not getting enough squirt..?
    Just need it to stop raining for a few days to fiddle with it.
    bct, brEad, Just Gary and 10 others like this.
  11. Marty Strode
    Marty Strode
    Paul, it looks perfect for the late 50's, early 60's, and the best part, you use your cars !
  12. Tim
    Tim
    from KCMO
    It’s really is pretty sharp looking, glad it’s hit the street!
  13. Paul
    Paul
    Editor
  14. jebbesen
    jebbesen
    from Winona, MN
    Any driving impressions of this style front end compared to the more conventional spring over on your other cars?
    Watching this build has been so helpful.
    loudbang, Stogy and Paul like this.
  15. jebbesen
    jebbesen
    from Winona, MN
    Do you have plans to paint, coat, or chrome the headers? Or will they stay bare?
  16. Paul
    Paul
    Editor
    It drives very nice, feels real good behind the wheel.
    It does ride a bit stiff with the full stack in the front and the heavy rear end, and of course the temporary seat, foam on plywood is not ideal.
    The headers will have to get something on them, probably just paint, unless a pile of cash falls out of the sky, then they'll get chromed.
  17. jebbesen
    jebbesen
    from Winona, MN
    I'm amazed on mine how freely the front end moves without the spring. No bind whatsoever with the 4 bar.
  18. jebbesen
    jebbesen
    from Winona, MN
    Paint is probably more period anyway on the headers. Maybe white or silver?
  19. Paul
    Paul
    Editor
    Probably just silver paint.
    loudbang, Stogy and jebbesen like this.
  20. jebbesen
    jebbesen
    from Winona, MN
    I've always liked white but when I was painting mine I decided to go silver after talking to a couple ceramic coating guys.
    I was using paint but they said even with the ceramic white can stain easily if something gets on it like oil and also it can turn kinda tan if it gets too hot. The welding on mine is no where near the quality of yours so I just had them sandblasted and painted them.
  21. 31Apickup
    31Apickup
    Looks good, plus know that that establishment behind it very well.
  22. Anderson
    Anderson
    Awesome example of an early T.
  23. Paul
    Paul
    Editor
    My wife has a couple spaces there and does the window. It's one of the better ones around here.
  24. 31Apickup
    31Apickup
    We always stop in there when we’re down that way.
  25. goldmountain
    goldmountain
    For a grocery getter, that sure is a small trunk.
    loudbang, Stogy and AndersF like this.
  26. Paul
    Paul
    Editor
    It will fit one bag in the trunk but the bag needs to be empty and folded flat.
    Dedsoto, brEad, Just Gary and 10 others like this.
  27. Paul
    Paul
    Editor
    Another dry day, another day for road tuning, smaller and smaller adjustments. Carbs, timing and toe, 1/8th turn here, a degree there, getting closer all the time.
    Tman, cactus1, bchctybob and 13 others like this.
  28. lake_harley
    lake_harley
    Great looking T....... and the pipe re-routing looks a lot nicer! :D
    Lynn
  29. Tim
    Tim
    from KCMO
  30. PINEAPPLE
    PINEAPPLE
    Man.. I have been reading this thread and your 27 thread for the last several days when I get some downtime. Thanks so very much for taking the time to share your process. It is so bitchin to see a true artist realize his vision using creative problem solving and ambition. Even more inspiring is the use of mostly simple tools in a home shop. Bravo, Paul. Fantastic hot rod building!
    cactus1, bchctybob, brEad and 5 others like this.
