Customs Smoke out the tail pipes
Discussion in 'The Hokey Ass Message Board' started by ahshoe, Nov 21, 2021.
  1. ahshoe
    ahshoe
    Got a real low mile s about 250 miles on a new crate 390 Ford motor I just installed in my 61 Galaxie. Runs out ok but does seems to pull back a little but it is dumping white smoke out especially coming down a hill and off the accelerator. Smokes out both tail pipes white smoke. I did a compression test .Cylinders run 120 lbs to 137 lbs. I plan on doing a leak down test but with fairly consistent compression .I don’t know if I have a problem bad enough to do a as leak down .But the smoking is not good .Any ideas? Motor is out of warranty as it took me too long to get the car done far enough to start to notice this problem before the warranty ran out .Would I be correct to say I have antifreeze getting into a cylinder?Any ideas.Should I do a leak down to see if I get bubbles in the radiator? That should pinpoint head gasket correct?
    Truck64 likes this.
  2. carolina chevrolet
    carolina chevrolet
    I would suspect valve seals first. A bad head gasket normally doesn't cause smoke.
    olscrounger and stillrunners like this.
  3. Does the vehicle have coolant lose issues? If it does, it could indicate a head gasket problem.
    My father had a '63 Galaxie with an FX automatic transmission, that had a vacuum driven modulator on the side of the transmission that was defective. The engine was pulling transmission fluid into the the intake, causing white smoke out the exhaust.
  4. White smoke..hmm how's the oil look?..milky?
    Water/coolant in the oil is my guess.
    Why, is the question..incorrect head gaskets?, did the head bolts get re-torqued after start up/cool down sequence?
  5. ahshoe
    ahshoe
    I have a manual trans .so no modulator valve .Yes I believe I am losing coolant . Just wanting to figure where and or why Thanks so far for the help.
  6. squirrel
    I had white smoke on an OT car years ago...pulled out the plugs, one was really clean....sure enough, that's the one that was sucking coolant in through a failed intake gasket.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    does the exhaust smell sweet? antifreeze burning smells sweet....
    Elcohaulic, AVater, SS327 and 2 others like this.
  8. ahshoe
    ahshoe
    Doesn’t really smell but I never got right into the tailpipe lots of condensation on the pavement after running for awhile plus I am picking up moisture on the LH breather bottom side when taken out and getting blow by there too. Any ideas here?
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    I've been known to stick my finger in the tailpipe and touch it to my tongue, antifreeze tastes sweet too
    SS327, F-ONE and BJR like this.
  10. BJR
    BJR
    You need to get out more! :D:p
  11. TCTND
    TCTND
    Power brakes? Could be a leaky MC/booster.
    ClayMart likes this.
  12. ahshoe
    ahshoe
    No power brakes
  13. miker98038
    miker98038
    If you’re losing coolant, do what Jim said in post 6. It’s been years since I pulled the intake on an FE, but if there was ever one I could screw up setting it in place, an FE was it. Including the rebuilder.
    A blown head gasket makes a lot of smoke, but only on that side (if the exhaust is separate). Followed by water in the oil, in my experience.
    The other thing is, how long has it been sitting? You can pick a lot of moisture up sitting, and 250 miles isn’t much. Depending on what’s used, I can remember when it took 500 miles to seat the rings.
  14. This is for REAL, an advertisement on the web.
    If you notice a small leak it is also possible to fix it without ever removing your head gasket. BlueDevil Pour-N-Go Head Gasket Sealer is an easy to use product designed for small head gasket leaks. BlueDevil Pour-N-Go Head Gasket Sealer is easy to use even if you’re not mechanically inclined and can save you a significant amount of time and money.
    To purchase BlueDevil Head Gasket Sealer you can visit any of our partnering local auto parts stores ....
  15. lippy
    lippy
    from Ks
    If it's an automatic, I'm going with modulator. If it's bad it sucks tranny fluid right in the carb or intake. JMO. Lippy
  16. 302GMC
    302GMC
    from Idaho
    Take the plugs out & pressure test cooling system ... if it holds pressure, leave it pumped up overnight. Next morning, spin it over. Don't stand in front of any plug holes.
    Blues4U and SS327 like this.
  17. ahshoe
    ahshoe
    4 speed manual trans
  18. lippy
    lippy
    from Ks
    Then I would say antifreeze. Lippy
  19. jaracer
    jaracer
    There is a kit to check for exhaust gas in the coolant. There is a bulb and vial with a liquid that turns color in the presence of exhaust gas. You get the engine warm and use the bulb to draw a sample of the air in the radiator above the coolant. If I remember right it turns yellow if exhaust gas is present. NAPA should have the kit.
    The other option is a cylinder leakage test if the leak is bad enough.
    SS327 likes this.
  20. TA DAD
    TA DAD
    from NC
    The rocker shafts can be installed upside down and this will cause a FE motor to smoke. But it would be oil smoke not AF smoke.
  21. ahshoe
    ahshoe
    Ok, here is what I am learning here and more information .Runs strong with a small pull back after warming up. White smoke out both pipes,slightly heavier on LH side but both quite a lot. Exhaust has an H pipe so I take it white smoke could transfer from side to side even if only one sides head gasket is bad....loosing coolant...compression is pretty consistant, pressure wise. No bad cylinder, Aluminum intake ,still large but not heavy . I used a stud method to drop in place., so bulk was not an issue .Should I try a leak down test next or just pretty much figure this a head gasket situation ?
  22. Doublepumper
    Doublepumper
    from WA-OR, USA
    An un-baffled valve cover can allow oil up into the PCV port and into the carb/intake. Something to check.
    49Olds, jimmy six and CaptainComet like this.
  23. jaracer
    jaracer
    Another head gasket checking method I've not tried, but it came from a very competent mechanic. You need a radiator pressure tester to do this. Fill the radiator to the brim and attach the radiator pressure tester. You want the radiator completely full so there is no air in the system to compress. Pump the tester to 1 to 3 psi, disable the ignition and crank the engine over. If you have a head gasket leak you will see the needle on the tester bump up as the offending cylinder comes to TDC. You can zero in on the problem cylinder by removing spark plugs one at a time.
    Thanks to Roy Gage for this information.
  24. sunbeam
    sunbeam
  25. I'd re-torque the heads before anything else (I've seen no mention of this so I am going to assume it was never done).
    Wanderlust and Truck64 like this.
  26. ahshoe
    ahshoe
    Do you retorque with a warm or cold motor?
  27. David Gersic
    David Gersic
    from DeKalb, IL
    The fluid test is free at Auto Zone. Just a deposit and return the empty bottle.
  28. Mr48chev
    Radiator pressure test first. You can pay the deposit on one at Autozone or O'Reilly's and use it and then take it back and not be out the 80.00 if you don't have access to one. I've done that as I don't have one and sometimes it is a couple of years between times when I need one.
  29. I always ran the engine to break the cam in then let it sit overnight so it would be stone cold, then do the re-torque.
  30. ahshoe
    ahshoe
    Just did the radiator (cooling system) pressure check COLD and no loss of pressure at all from anywhere .Pressure on the guage I set at 7#......It held perfect . Left on for about 10 minutes.
    Also retorqued the intake and head bolts COLD although they never actually retorqued at all. They were still at the recommended torque?
