Technical Power Transistor?
Discussion in 'Traditional Hot Rods' started by scott Hrncirik, Nov 18, 2021.
  1. scott Hrncirik
    scott Hrncirik
    I need some advice. I have a 1932 Ford running a 350 with a 671 blower. I was working on the car and bumped a “power transistor “ on my firewall and it fell into my rocker panel and I was unable to retrieve it. I was on the road when this happened so not knowing what it was I cut the wiring from between the Mallory coil and the “power transistor” and the ballast resistor. This bypass got me back on the road but the car runs like crap. I was able to get the piece out of the rocker panel but don’t remember how to wire it back in. The resistor had 3 wires to it ground, positive, negative. Which one would go where? See pictures.
  2. Budget36
    Budget36
    Search for “data sheet for xxxx” you should find the specs on it.
  3. PhilA
    PhilA
    1. Hydro Tech
    The resistor went to ignition switched power?
    If so I'm thinking middle connector goes to coil +
    Coil - goes to the right hand leg (looking at the transistor like you have in the photo)
    Middle transistor leg goes to ground
    Left transistor leg goes to the points
    Ballast transistor for the coil to drop the voltage to the coil
    The transistor acts as the points do by opening and closing conductivity. That open and close is triggered by the points, saving the contacts from wear.
    Phil
  4. jaracer
    jaracer
    The middle can't be connected to coil + and also ground. Eliminate the ground in your explanation and I think you have it.
    Hnstray likes this.
  5. PhilA
    PhilA
    1. Hydro Tech
    It's it's a center tap wirewound yes it can- it'll act as a voltage divider.
  6. This is not a resistor, it is an NPN power transistor. It will (should) have a resistor connected to the Base ( left pin when looking from the front), which is probably taped into the wiring loom somewhere. The Collector (middle pin) would be connected to your coil negative. The last pin (Emitter) should go to ground (if you have a negative earth system). There should be something in that circuit to quench the back EMF from your coil, too.
    This is your most basic transistor ignition, hopefully the rest of it is there somewhere. There is usually a few more components than just the transistor in these systems.
    If strip the loom back enough, you could re-connect it , if you are careful to not over-heat the stubby pins that are left on the original, or get a new one. They are only a few bucks.
  7. squirrel
    that's a new on on me...interesting!
    a little googling:
  8. Truck64
    Truck64
    from Ioway
    So what do it do?
  9. PhilA
    PhilA
    1. Hydro Tech
    Does the heavy lifting of switching the coil on and off.
    The points are just used to switch the transistor on and off instead, which is a minuscule current, with no sparking to dirty up the points.
    Truck64 likes this.
  10. PhilA
    PhilA
    1. Hydro Tech
    You're right, I read the datasheet for the NTE37 (PNP compliment). With the PNP you just dump through the transistor with maybe a resistor to limit the current through the base.
    He mentioned a 3 position ballast resistor, unless I misread, though.
  11. seb fontana
    seb fontana
    from ct
  12. Blues4U
    Blues4U
    from So Cal
    Notice this is on the positive side of the coil. Normally the points are on the negative side of the coil. Connected like this the transistor will interrupt the flow of current through the coil, triggered by the points. When the points close the transistor will connect the collector and the emitter and current will flow. When the points open the connection between the collector and the emitter opens, current stops flowing. The points are shielded from the high voltage generated by the sudden collapse of the magnetic field, so no condenser is needed.
    ETA: While I was being verbose about it, PhilA cut out the b.s. and got to the point.
    PhilA and G-son like this.
  13. Blues4U
    Blues4U
    from So Cal
    No ballast resistor needed either. Full voltage to the coil all the time for a hotter spark.
  14. I would also assume that the switching is faster because you don't have to wait for the capacitor to charge. But if I'm reading this right, this also precludes you from using a ballast resistor so you need a coil that can operate on the full system voltage.
  15. G-son
    G-son
    from Sweden
    Can't see why you couldn't keep the ballast resistor. You just don't have to have it to keep the points healthy, but skipping it is an option.
    Blues4U likes this.
  16. scott Hrncirik
    scott Hrncirik
    Thank you for all of the information. I don’t have points in the car it was swapped over to a Mallory Unilite. Does that make a difference?
  17. squirrel
    I expect it does. Info like that would be helpful in the first post.
  18. Ebbsspeed
    Ebbsspeed
    That is a pretty darned simple points-saver circuit. Continuous current rating of that transistor is 12 amps, so it should work a long time in an environment where coils are typically a couple ohms minimum and V8 point dwell time is 45°.
    @scott Hrncirik what was that transistor mounted to, some kind of an isolated heat sink? The diagram @squirrel posted says not to ground the mounting tab, which makes sense as it is typically connected to the collector lead and grounding it would render the circuit useless.
    EDIT DUE TO NEW INFO: If the igition system is a Unilite then it's "pointless" to even have this transistor wired in to the system.
    Blues4U and PhilA like this.
  19. scott Hrncirik
    scott Hrncirik
    Sorry for the lack of info. It was mounted to a steel member under the dash with a thick white glue (I assume to keep it from grounding).
  20. Truck64
    Truck64
    from Ioway
    Heatsink compound
    XXL__ likes this.
  21. If the heatsink is not meant to be grounded, there will be a tiny nylon insulator which keeps the mounting screw isolated from the tab. Make sure it goes back on, and , as said above, the white gunk is heatsink compound. Scrape some off the old one if you can, and use it to mount the new one.
  22. blue 49
    blue 49
    from Iowa
    Looks somewhat like the Ford TFI module ignition wiring, triggered by points.
    Gary
    pprather likes this.
