Technical Cast iron Mercury intake
Discussion in 'Traditional Hot Rods' started by flatheadfever, Nov 12, 2021.
  1. I have a cast iron mercury 4 bolt intake that I was planning on selling.
    What is a fair price to ask?
    It is in good shape.
    Thanks
  2. FrozenMerc
    FrozenMerc
    What engine family? MEL, Y-Block, Lincoln Y, FE, 385 Lima, Flathead, 335 Cleveland, Windsor, Big Six, Falcon Six, etc... Lots of different engines wore Mercury badges.
    I would guess fair price is somewhere between it's weight in scrap iron and a couple hundred bucks. Or just a couple hundred bucks if it is an FE intake since that is what it is worth in scrap iron.....
    loudbang, Truck64, Deuces and 3 others like this.
  3. Lost in the Fifties
    Lost in the Fifties
    I gave $50 for a flathead intake to be able to use a 2GC carburetor. Condition will dictate price.
    Deuces likes this.
  4. 19Fordy
    19Fordy
    Photos please. Also, is there a part # on it?
    Deuces likes this.
  5. How long is a string?
  6. Budget36
    Budget36
    Twice as long as 1/2 it’s length. ;)
  7. v8flat44
    v8flat44
    You mean like how much .... ah forget it...
    Deuces likes this.
  8. Late mercury flathead 8CM-6520
    Deuces likes this.
  9. squirrel
  10. Best of my knowledge Ford never used the 4 bolt base Carb on a Flathead, only Merc 50 and 51. That said I have 2 just like it I haven't been able to give away for 40 years. Good luck selling it.
  11. jimmy six
    jimmy six
    Can use in factory stock class with an adapter a Holley 500cfm will fit.
    stillrunners and Deuces like this.
  12. Rochester 2g fit the bolt pattern.
    Robert J. Palmer, Deuces and Hnstray like this.
  13. $50 max. And even then it could take awhile.
    Deuces likes this.
  14. Atwater Mike
    Atwater Mike
    I had one for years... it went with some old stock stuff, some old guy bought it. Said he remembered all those parts..
    Deuces likes this.
  15. And a Stromberg,,,,and a Carter.......and what he said ^^^^^
  16. Mr48chev
    I'd have to agree with the idea that if someone handed you 50.00 for one grab the money and run before they change their mind.
    To add to that I have a pair of nice heads that match that intake and if someone were to hand me 25.00 they would be welcome to them. I picked them up cheap at a local swap meet years ago because one of my heads on my 8 BA has the area around the front bolt hole for the thermostat housing broken out and I hadn't found my aluminum heads yet.
  17. Patrice
    Patrice
    from France
    French flathead have the 4 bolts pattern too with zenith 32 ndix carburator.
  18. You may want to list it in a vintage oval track site, some clubs require the use of a single carb. The flathead car racing with us is a running the Merc intake and a heavily modified Rochester 2 BBL.  upload_2021-11-13_5-40-41.png
    I am running a 500 CFM Rochester 2BBl modified by JET performance on my 261 Chevy.
  19. sloppy jalopies
    sloppy jalopies
    just sold an 8ba flattie fuel pump stand, made the guy take the intake with it...
    best of luck...
    Stan Back and Deuces like this.
  20. 1946caddy
    1946caddy
    from washington
    I paid $75.00 shipped to my door in 2017. I guess nobody with these freebie's read my want ad when I was looking.
    Budget36 likes this.
  21. tubman
    tubman
    I believe a Mercury 4 bolt manifold is a desirable piece and $50 is probably a bargain in most areas. The 2G on one is a great update for a street driven car with minor mods to the engine. I will buy any one I see for $20 or less. I haven't bought one for at least 5 years.
    And while an 8CM Mercury manifold is a decent upgrade to a flathead Ford, the 8CM heads are a downgrade.
    stillrunners likes this.
  22. 6sally6
    6sally6
    Give it to somebody just getting started in the hot rod world. You'd be surprised how good it makes you feel. Someday......maybe..he will return the favor.
    That's sorta how it works ya'know!!
    6sally6
    Texas Webb likes this.
  23. Dang, now I feel bad. I bet I don't look in the Wanted adds twice a year, and that's generally by mistake. You might even be close enough we could have done a meet-n-greet.
  24. 1946caddy
    1946caddy
    from washington
    That's OK, I wouldn't feel right if I didn't overpay for everything.
    36 Ford PU, 49 8 BA, 2 G carb, EAB heads, T5. Still collecting parts.
    Pist-n-Broke and Budget36 like this.
