Customs 49 Ford Coupe
Discussion in 'The Hokey Ass Message Board' started by LSJUNIPER, May 13, 2021.
  1. LSJUNIPER
    LSJUNIPER
    from ct
    New ride.
    slayer, desertdroog, hfh and 16 others like this.
  2. i.rant
    i.rant
    1. 1940 Ford
    Nice,enjoy!
    LSJUNIPER and lothiandon1940 like this.
  3. 210superair
    210superair
    from Michigan
    Hell yeah. Let's see under the hood...
  4. LSJUNIPER
    LSJUNIPER
    from ct
    OK, Will take some pics under the hood when I get home from work.
    210superair and chryslerfan55 like this.
  5. jaracer
    jaracer
    Back in 61 an old guy pulled into a filling station I hung around. He had a 49 Ford 4 door and it was running poorly. He was tired of messing with it as no one seemed to be able to get it to run right. He didn't want to spend any more money on it so he sold it to the mechanic for $15.00. Points, plugs and a set of plug wires and it ran fine. I helped modify it for circle track racing which amounted to breaking out all the glass, doing away with the rear seat, installing some old military seat belts and paying a guy to make a steel protection set of bars for the radiator. It lasted two nights before it bit the fence and was destroyed. The engine ended up in a 39 Ford coupe.
    hfh, gary macdonald, wicarnut and 2 others like this.
  6. D type
    D type
    Great looking car -- have fun and be safe
    LSJUNIPER likes this.
  7. Great looking car. I like the understated visor ... a lot.
    chryslerfan55 and LSJUNIPER like this.
  8. LSJUNIPER
    LSJUNIPER
    from ct
    11111111111111111111111111111111.jpg 4E27C620-BFDC-45F0-95E0-C523BB2DD639.jpeg DBA13A2B-D1BA-4337-B2CB-378DF19352F8.jpeg View attachment 5062421 D127E6BF-05F1-421D-931F-1716F54CCBE1.jpeg It has Mercury heads but I don’t think it’s a Merc motor. Holly carb , electric fuel pump, MSD distributor. One day I will put some Stromberg carbs on it, for now I’m going to enjoy it.
  9. rustymetal
    rustymetal
  10. sidewayzz69
    sidewayzz69
    Very nice car.
  11. v8flat44
    v8flat44
    Now you've done it; I am having a Flat Attack . She's real fine, your 49......
  12. LSJUNIPER
    LSJUNIPER
    from ct
    one.jpg two.jpg According to Van Pelt Sales, “the only visual method of differentiating Mercury and Ford Flatheads is to look at the front counterweght of the crankshaft. Mercury crankshafts have a longer stroke and are identified by a dimple on the top of the crankshaft counterweight” That being said I may have a merc motor in there after all.
    gary macdonald likes this.
  13. 210superair
    210superair
    from Michigan
    The only thing I would do is ditch the puke bucket for a puke can. It'll really clean up that engine bay, cheap. This ain't my car, but this is the same puke can I got.
  14. F-ONE
    F-ONE
    from Alabama
    That's a very nice car.
  15. Elcohaulic
    Elcohaulic
    That is a real nice old Ford..
    Why do they have the whole radiator blocked off.. There loosing a lot of free cooling as the car goes through the air.. Another con when it comes to electric fans vs Clutch fans.
  16. F-ONE
    F-ONE
    from Alabama
    OK, Ok....
    You must be talking about this one...
    I thought you were talking about the '49. With all the factory sheet metal in place air was forced through the radiator. Below you can see that the bottom air dam is missing.
    In the photo below it appears the air dam is in place. It's hard to tell. That could be the concrete floor.
    Anyway, there should be a sheet metal pan below the radiator between the frame rails. This directs air through the radiator and over the engine.
    It's very common for this piece to be missing.
  17. LSJUNIPER
    LSJUNIPER
    from ct
    Thanks, I was thinking of ditching it for a better one... You answered that question. Where can I find that "puke can"?
  18. belair
    belair
    one of my favorites. Congrats.
  19. 210superair
    210superair
    from Michigan
    All over. There's one at Speedway for like $40, but I can't speak to the quality. Just Google it and you'll find plenty of options. I can photograph mine tonight after work if you want to see how it is under the hood....
  20. LSJUNIPER
    LSJUNIPER
    from ct
    Yes send a pic when you can, thanks .
    210superair likes this.
  21. gary macdonald
    gary macdonald
    In order to determine if its a mercury, you nee to remove the oil pan to inspect the counter weight or if a cyl head is off , measure the stroke . Nice no matter .
  22. tubman
    tubman
    You said "Holley carb". Both Ford's and Merc's had Holley's. The important thing is whether it has a 3 bolt carb (Ford) or a 4 bolt carb (Merc). If it has both Mercury heads and a Mercury carb, there is a little better chance that the engine is a Mercury. Most people know that putting Mercury heads on a Ford is a bad idea, since you lose compression because of the larger combustion chamber volume.
  23. 210superair
    210superair
    from Michigan
    lothiandon1940 and LSJUNIPER like this.
  24. LSJUNIPER
    LSJUNIPER
    from ct
    Thank you sir. I am going to do the same. What length is it?
    lothiandon1940 likes this.
  25. 210superair
    210superair
    from Michigan
    I believe it's 15 inches, give or take, they make 15,16,17, and a bunch of smaller ones starting at 9 I think?
  26. LSJUNIPER
    LSJUNIPER
    from ct
    New over flow / puke tank is in. Got to run the line and I’m going to remove the brackets I made for it and paint them.
  27. LSJUNIPER
    LSJUNIPER
    from ct
    Anyone ever put seatbelts in the back seat of there shoebox? Looking to do that for the grand kids ice-cream run? Where did you purchase the belts?
  28. LSJUNIPER
    LSJUNIPER
    from ct
    Got caught in a rain storm a few weekends ago and just this past weekend got a chance to clean and wax the shoebox.
    One thing about WAX.jpg that is you find every flaw there is in the car and there are definitely some flaws. But that's what makes it a driver. Here's a pic of my grand kid, one and a half years old, to young to start helping gramps with the classic?
  29. brady1929
    brady1929
    Congratulations.
  30. LSJUNIPER
    LSJUNIPER
    from ct
    Welp, I was going to use this thread as a history for my 49 , was going to post car shows, ice cream trips with the grand kids and such. Well, do to covid, or more precisely mandates, I may be out of a job soon. My wife also, we work at the same place. So she gone to a good home.
