Technical Tilt steering column rebuild
Discussion in 'Traditional Hot Rods' started by Cramur, Oct 18, 2021.
  1. Cramur
    Cramur
    5BA60491-7346-4B3B-BEE7-CEA33A366832.jpeg 45EF448F-BBF5-429F-B600-F82D6BDBA965.jpeg 0BDFF90E-744A-4078-A781-AD39436BDBB4.jpeg Hi, I have a 64-66 Pontiac floor shift tilt steering column With an external signal switch operated by a cable. I’m trying to rebuild it but I’m having trouble getting to the 4 screws. Three are out but the last one is covered by the bearing hub, how do I get to that last one? Is the collar just pressed on the hub?
    any help would be great, it’s driving me crazy!
  2. Jokester
    Jokester
    Did you look for it on Youtube? They have videos on how to repair almost anything.
    I've done it before, but it has been years.
    .bjb
  3. Cramur
    Cramur
    I’ve searched for videos but everything I’ve found is for the non cable type 67 and newer
  4. fiftyv8
    fiftyv8
    from CO & WA
    The folks who make those videos can be messaged , so if you see one that is close tpo what you have get in touch with them.
    I have a couple of non steering column videos on YouTube and I've been contavted several times with questions.
  5. 5window
    5window
    Chrysler licensed the GM designs for their Tilt-n-scope column. That's what I have. You might search for that,too. I'll see what I can find tomorrow.
  6. DDDenny
    Yes, those outer covers are pressed on and are fairly easy to buggar up and can be tricky without a factory style puller. I sort of copied the GM puller shown in the repair manual, it grips the cover but also catches the windows in the cover, one for the turn signal and one on the opposite side for the emergency flasher button.
    I made this for a 67 GM tilt column but you should be able to make one for yours fairly easily, if you already have some sort of slide hammer you are half way there.
    Budget36 likes this.
  7. treb11
    treb11
  8. Mr48chev
    That one is a later column and way different than what he is working on. I've had a lot of those apart to tighten them up after my wife worked them loose pulling herself up in the seat with the steering wheel.
  9. 5window
    5window
    Could be.
  10. Cramur
    Cramur
    Thanks for the updates! I managed to get the collar off. The next struggle was the pins holding the tilting hub. I had to clean one side of the hub around the pin with with a very small dremel bit but then the pins pulled right out with access to the 4 screws holding the other half of the hub to the column. Thanks again everyone!
    5window likes this.
  11. 5window
    5window
    You should write it up for Tech Week.
  12. This is the best How-To I have found on rebuilding the GM tilt column. Key to those blasted 4 bolts is removing the two tilt axle pins. Complete tear down and rebuild is the only good way to do it right.
    https://www.fiero.nl/forum/Forum2/HTML/088020-3.html
