Technical Update: Does this look bent?
Discussion in 'The Hokey Ass Message Board' started by ZZ Top Chop, Oct 18, 2021.
  1. ZZ Top Chop
    ZZ Top Chop
    I have been nursing the 327 this year in my avatar so I could make it thru the show season. It has blow by, it smokes out the oil filler. I've done a compression test, numbers weren't great (23psi on this cylinder) and it has had a tick. I haven't noticed any loss in power at all. So I pulled the valve cover off and was wanting to see if I had a lifter that needed adjusted. Started the car, it ran for 3 or 4 minutes and died and it will not start at all now. (Maybe unrelated). 20211018_113032.jpg I noticed this valve is off. Thoughts? And if it needs the heads redone, I'm thinking of replacing the motor as I've not been happy with it anyway.
  2. squirrel
    Can you wiggle the valve retainer sideways? It looks like that valve is not in line with all the others, like the guide is completely gone.
  3. ZZ Top Chop
    ZZ Top Chop
    No movement.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I have to go with what Jim said as well. Bring the piston all the way up on that cly. and pull valve spring off valve and take a closer look.
    lowrd, alanp561 and Tman like this.
  5. ZZ Top Chop
    ZZ Top Chop
    I turned the motor over and as you see on the upstroke of the valve it's not as noticeable. 20211018_120721.jpg
  6. Hollywood-East
    Hollywood-East
    I would at least pull the pushrod an check straightness, check bumping over if valve is move'n around like squirrel said
    Budget36 and Elcohaulic like this.
  7. ZZ Top Chop
    ZZ Top Chop
    So that's why it won't run with the valve cover off?
  8. saltflats
    saltflats
    from Missouri
    Does that valve spring look funny at the head surface in the first picture?
  9. Looks like the adjusting nut is really down there.
    olscrounger, Jibs, 1929rats and 11 others like this.
  10. That was my thinking too. they look like they are way too tight
    jimmy six, Boryca, LOST ANGEL and 3 others like this.
  11. 57JoeFoMoPar
    57JoeFoMoPar
    23 psi is basically a dead cylinder. Is that an intake valve that you're talking about? Are you getting any popping in the intake? Smoke out of the exhaust? The compression has to be going somewhere, either around the rings or around the valve and guide.
    GlassThamesDoug and Driver50x like this.
  12. ZZ Top Chop
    ZZ Top Chop
    20211018_124351.jpg I just noticed this, the washer on the rocker arm is busted? How? Something else cause this, what's my next move?
    Tman and Johnny Gee like this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Valve float
  14. Hollywood-East
    Hollywood-East
    There's Definitely a snafu there!
  15. This speaks volumes.
  16. ZZ Top Chop
    ZZ Top Chop
    Exhaust valve. No noticable smoke and seems to run fine. It's off but feels more like timing than anything else
  17. bchctybob
    bchctybob
    I had three engines that I ran until they just wouldn’t start anymore, it turned out that they just didn’t have enough compression left to function. Sounds like you are there my friend. My SBF had the valves sunk an 1/8” into the head casting thanks to our modern fuels. You just need to bite the bullet and either rebuild the poor old thing or replace it.
    rladams65 likes this.
  18. ZZ Top Chop
    ZZ Top Chop
    If I can get it going for just another month or so it would be great but I did make it this far. Looking at a Blueprint motor
  19. squirrel
    just buy a new rocker arm at the parts store, it will have a new pivot ball. Put it on, adjust the valve, see how it does.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
  21. ZZ Top Chop
    ZZ Top Chop
    I'll try that, thank you.
  22. ZZ Top Chop
    ZZ Top Chop
    HAHA!
    rladams65 and Johnny Gee like this.
  23. ZZ Top Chop
    ZZ Top Chop
    Push rod is straight, I rolled it across our quartz counter top, shhh, don't tell my wife.
    raven likes this.
  24. ZZ Top Chop
    ZZ Top Chop
    So I'm waiting on a rocker arm now as I live on a remote island called Southern Indiana. Not covid related its always been this way since we moved here.
    alanp561, -Brent- and scotty t like this.
  25. Can't see how the push rod could have been bent and pushing the rocker to one side,....with guide plates ;-)
    squirrel likes this.
  26. Hollywood-East
    Hollywood-East
    Possible in valley, Below guide plate...
    But apparently not an issue here... And the plot thickens..
  27. Budget36
    Budget36
    Seems the rocker moved through the lift of the cam by looking at the pics.
    As noted the broken ball is probably issue. But take a bent wire, run it through a hole, it will lean/move to a different spot as it goes higher and lower.
    I think that’s why the suggestions to look at the push rod were warranted.
  28. Of course everything should be looked at when it's apart. But once he loosens the lock nut it would be apparent where the trouble lies. Top of the rocker where it belongs, with the guide plate ...Bottom, not so much so.
    I would guess someone along the line , trying to eliminate a clickedy -clack, ran the lifter plunger down to where it was acting like a solid but with no lash ... Rocker at an extreme angle , stress on the ball...crack!
    Now we have to figure out what's wrong with that one lifter...or cam lobe. ;-)
    Johnny Gee likes this.
  29. ZZ Top Chop
    ZZ Top Chop
    I've had the car for 4 yrs, valve cover has never been pulled. Motor was rebuilt (whatever that's worth) before I acquired it and I'd guess it has less than 1000 miles on it. I got the rocker off, I don't see anything other than the broken washer. But I can't see that being the only issue but a symptom of something else.
  30. sdluck
    sdluck
    Rocker stud coming out of the head or the cam is going bad.
    Tickety Boo and Hotrodmyk like this.
