FOR SALE: Complete rear end from a 1933-1934 Ford Flathead. Includes driveshaft, torque tube, radius rods, and partial rear spring pack. No brakes though. Banjo housing was pulled apart prior to my purchase by the seller who acquired from a 1933-1934 Ford collector to inspect ring & pinion so would need new gasket shims installed. Desirable 3:54 ring & pinion. Can be used in a 1932 Ford if you shorten the driveshaft and torque tube. 1933-1934 is same rearend as late 1932 Ford with the scalloped housing and supported pinion bearing unlike the round early 1932 Ford which was like a model A. 1933-1934 radius rods mount at a different angle than the 1932 Ford also. $550. Local pickup only near Atlanta, GA. CASH only.
