Technical 1939 Ford Sedan Rear Fender Fitment
Discussion in 'The Hokey Ass Message Board' started by 32SEDAN, Oct 11, 2021.
  1. 32SEDAN
    32SEDAN
    Anyone have experience fitting 1939/1940 Ford rear fenders from United Pacific? I’ve got it mocked up and the tire is offset in the opening to the rear about an inch. The running board and fender bolted up with little difficulty. Any ideas? I know OEM fenders fit best…
    Thanks!
    lothiandon1940 likes this.
  2. For whatever reason, it seems like '39 and '40 Fords are some of the most difficult to get the wheel/tire centered in the opening of the fender. If you look at them at a show or event, most are not well centered. I don't have an answer for you, sorry. Hopefully someone will chime in with their efforts to solve this issue. It could be one of those things where a "happy medium" is all that can be achieved.
    AVater and 32SEDAN like this.
  3. I made your picture a little bigger so it's easier to see the discrepancy. 4594161-a540031fa3f3851fa40498ce2fb983c9.jpg
    32SEDAN likes this.
  4. 32SEDAN
    32SEDAN
    thank you!
  5. uncleandy 65
    uncleandy 65
    I had a 38 Chevy that had the same problem. The spring bolt on the stock springs is not the center of the fender opening. I had to make a bracket to offset the spring bolt.
    lothiandon1940 and 32SEDAN like this.
  6. 32SEDAN
    32SEDAN
    Thanks. What did your bracket look like?
    uncleandy 65 and lothiandon1940 like this.
  7. olscrounger
    olscrounger
    very common on 40's. Look at many pictures--you will see most are not centered. Even stockers are off a bit toward the front. Many I have done required centering the rearend-usually as much as 1" but most times 3/4"
    Does the car have crossspring or parallel leaves?
  8. 32SEDAN
    32SEDAN
    parallel leaves.
  9. olscrounger
    olscrounger
    Several ways-redrill main leaf forward or buy blocks with adjustable offset-Speedway has them or make them.
  10. 32SEDAN
    32SEDAN
    Thanks I will check them out!
  11. Pete Eastwood
    Pete Eastwood
    from california
    Is it a fender problem or a chassis problem ?
    Was your wheel centered with the original fenders ?
    32SEDAN likes this.
  12. The first thing is to make sure your wheelbase is correct, then make sure it's square. Then measure the spring to be sure the 'center' bolt is centered. Since it is a parallel conversion, redrilling spring pads may be required.
    32SEDAN likes this.
  13. 32SEDAN
    32SEDAN
    You’re on to something. The wheelbase is 112.5” and 1/2” longer than stock. That’s the source of this issue. The axle will need to move forward
    thanks!
  14. 32SEDAN
    32SEDAN
    New chassis, new fenders
  15. 19Fordy
    19Fordy
    IMG_8862.JPG 40 ford side view0001.jpg IMG_0060b.jpg View attachment 5197654
    This rear wheel is centered using the original 112 in. wheel base and 40 Ford rear end.
    Tire is 7:60 x 15. Previous 8:20 x 15 tire was also centered. Front tires are 5:60 x 15
    on a 4 in. dropped axle and reversed spring.
  16. 32SEDAN
    32SEDAN
    Perfect! That’s the spacing I’m trying to achieve
  17. hotrodjack33
    hotrodjack33
    I ran into the same problem putting the '36 Cabriolet back together...both sides equally a little off center...fortunately, skirts hide the issue;)
    32SEDAN and lothiandon1940 like this.
  18. uncleandy 65
    uncleandy 65
