Technical SBC fuel pump/oil leak
Discussion in 'The Hokey Ass Message Board' started by 57 HEAP, Oct 7, 2021.
  1. Is it possible for the fuel pump to leak oil?
    I have an oil leak "around" the fuel pump and it might be from the pump itself. I don't want to do this job twice, so if the pump could leak, what do I look for?
  2. SEAAIRE354
    SEAAIRE354
    There is a threaded hole on the front of the block that goes into the fuel pump pushrod. It needs to have a short 3/8-16 bolt in it or oil will come out. And it’s possible that the two gaskets are bad. I don’t believe I’ve ever seen a pump actually leak oil.
  3. ^^^^^^^^^^^^^^ X2
    lothiandon1940 likes this.
  4. Deuces
    Deuces
    Yeah, replace those 2 gaskets....;)
  5. Thanks all. I know about the bolt hole. I'll double check that, but I plugged it.
  6. TA DAD
    TA DAD
    from NC
    The pump can leak oil out one of the holes in the pump body itself.
    ottoman and 2OLD2FAST like this.
  7. Dennis D
    Dennis D
    Above reply is correct. There is a seal on the shaft of the diaphragm that will let it leak out the weep hole. If it is a screw together type pump you can buy kits to rebuild it.
    FuelRoadster, Deuces and 2OLD2FAST like this.
  8. squirrel
    pumps are cheap, and yes they go bad....
    VANDENPLAS, Blues4U and Deuces like this.
  9. A screw type is what I have. Rebuild is a good idea, but I haven't any luck finding the proper kit.
    Yes they do...……. just wish they would last longer.
    Deuces likes this.
  10. Dennis D
    Dennis D
    Terrill Machine in Texas 254-893-2610. Should be a number stamped in the flange on the bottom left. Some had a small metal tag on them with the number.
    Deuces likes this.
  11. goldmountain
    goldmountain
    Check your oil pan bolts, it might be coming from there.
  12. Thanks for the info Dennis.
    Pan bolts, check!
    Deuces likes this.
  13. SS Pete
    SS Pete
    I had a 5 week old chrome leak big time. the seal inside the pump was not "staked " to the pump casting . i checked another brand and it was.. so much for "speed equipment".
    Deuces likes this.
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    Most likely the front seal or front timing cover seal throwing oil .
  15. doug schriener
    doug schriener
    HI-Yeah I have seen a fuel pump leak oil out the small vent hole in the pump-not common but can happen.
    Desoto291Hemi and Deuces like this.
