Technical Banjo axle thread repair help
Discussion in 'Traditional Hot Rods' started by novaskilling, Oct 7, 2021.
  1. novaskilling
    novaskilling
    Picked up my 40 banjo rear and one axle end has damaged threads, is there anyway to repair this?
    thanks Chris
  2. I can't remember the size off the top of my head, but I'm sure someone makes a die to fix those threads because I had to buy one a few years ago because I had the same problem.
    5/8-18 I THINK, you should verify before purchase.
  3. novaskilling
    novaskilling
    Thank you very much! I’ll confirm the size
  4. Andy
    Andy
    I would just grind the damaged part off. Do not try to thread a die on it. It will go on crooked and ruin the axle.
    I can retread just the damaged part with a split adjustable die. I start from the good threads and move outward.
    I would be happy to do it for free. Where are you?
    Ps, The threads are special close tolerance threads due to the high load put on them.
  5. vtx1800
    vtx1800
    The threads you show are worse than the ones I needed to repair but this is what I did, I took a nut, sliced it in half and welded it to a vise grips to make a pseudo tool to straighten the threads on a Dana 44 axle, I'd use a file first to clean them up a bit and the fact that the damaged threads are outside of the cotter pin hole means there shouldn't be a strength issue.. IMG_3463.JPEG
  6. Nice work!
    46international and seb fontana like this.
  7. hemihotrod66
    hemihotrod66
    Try to find yourself a thread file....Looks like the school of hammerolgy on the end of the axle....
    SS327 likes this.
  8. xix32
    xix32
    That's a 5/8-18 thread, don't try to run a die on from the outside. It's way too easy to cross thread it.
    Rather grind a vee in one side of a die and hold it in a vise, hit it with a hammer to break it in half, it will fit back together nicely. Then place it together on the inside ( good) part of the threads, then put the holder on over the die to hold it together, then turn it off ( not on) to fix the bad thread area.
    5:8"-18 die.JPG
  9. oldsman41
    oldsman41
    Gee I’ve seen worse if you have a thread file or can get one start with that, than you should be able to do a die on it to clean it up. If you have a good ace hardware take it down there and they should be able to help you with the sizing.
  10. oldsman41
    oldsman41
    32 has a great idea right there
  11. Petejoe
    Petejoe
    from Zoar, Ohio
    What a great idea XIX32!
    Never thought of doing that.
    This is why the hamb is so great.
    Full of people who fix shit not replace it.
    Truckdoctor Andy, Wanderlust and Tman like this.
  12. Doublepumper
    Doublepumper
    from WA-OR, USA
    You may want to see if one of these is available from a tool rental outfit.
    Truckdoctor Andy and Carter like this.
  13. birdman1
    birdman1
    Thread file, every GOOD mechanic has at least two
    aa
    Truckdoctor Andy likes this.
  14. novaskilling
    novaskilling
    Thanks so much for the advice and the offer to help, I’m in Canada so we’re a little far apart haha. I did find a vintage axle/spindle tool that has multiple thread chasers built in that splits in half. Picking it up tomorrow and will give it a go!
    dwollam likes this.
  15. novaskilling
    novaskilling
    brilliant!! Thank you for the idea!
  16. Doublepumper
    Doublepumper
    from WA-OR, USA
    When you need them, they are indispensable.
    thread files.jpg ;)
  17. 51 mercules
    51 mercules
    This is what I use! Axle Threading/Re Threading Tool. You can find them on Ebay.[​IMG]
  18. I have a couple also, just be careful and take it slow.
    Truckdoctor Andy and 51 mercules like this.
  19. Budget36
    Budget36
    That’s what I’d do too. The threads that are damaged are just there to start the castle nut. That portion of the castle nut isn’t providing any clamping force, it’s just there to put the cotter pin in and hold it in place in case it were to back off.
    Truckdoctor Andy and alanp561 like this.
  20. Aaron D.
    Aaron D.
    I would take a Dremel and grind the bad threads off. The nut is further on the axle when it's tight anyway.
    Andy likes this.
  21. 19Fordy
    19Fordy
  22. That’s not a vise grip, that’s a Lever W Wrench. You are the only other person that I’ve ever seen with a pair. My Dad has two pairs, and got them when we lived in Eastern Iowa. Nicely done on your tool!
