I purchased frame webbing from a well known hot rod shop. For the life of me I cant seem to figure a way to put holes in this stuff. It looks like seat belt material. I guess I could just cut it so it just ends before and after any given hole. What have you guys done in the past? This is for my 34 3-w ford. Thanks Paul
You want a hollow punch set. Similar to this one or the ones shown below it. eBay item number: 182421204502 You should be able to find sets locally or find them on Amazon. They are handy as hell for gasket making as that is what I bought my first small set for about 50 years ago.
Piece of copper tubing, hold it with vice grips, heat it with a propane torch and melt the holes into the webbing, Also cauterizes the hole so it doesn't fray.
.or you can fold it at the hole centerline and cut a vee into it .. slightly smaller than the bolt size and the bolt will slip past it.. square hole round peg idea...
This is the ticket. My dad had a dozen we used from belts, gaskets and mounting mudflaps. Lay thee material on a block of wood on a solid base, hammer a hole. Found it best to use a short handle 2lb sledge. Not much effort needed.
I've made replacement rubber pieces for exhaust hangers a number of times by using a razor knife to cut a piece out of a tire sidewall and my hollow punch to punch the holes in it. That started after I bought one at the parts house and it was made out of a sidewall out of a tire complete with part of a whitewall.
Thanks guys , I did try drilling but just caused a frayed mess with this material. I do have a cheapo hole punch set I use for gaskets, and holes in belts,,,so gave it a shot. Results were not as clean as Id like. Could be they were not sharp enough. So I broke the propane torch. Now the hot tip worked really nice. I was impressed. Then trying to cut off my test piece off the roll using sheet metal snips was not getting a clean cut. The heat worked so well, I heated up a old putty knife and made a very clean cut. Perfect, With the from you guys, I can do the holes and cut this stuff off nice a neat. Thanks Very Much Guys
