Technical ***September 2021 Banger Meet Thread - Happy Equinox***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 1, 2021.
  1. Jiminy
    Jiminy
    Link to previous month: August 2021
    Old Dawg informs us there is an effort to resurrect a F.A.S.T. newsletter but it would require 400 subscribers (minimum number to attract vendors). Subscription price is unknown at this point (2021/9/1) but if you are interested send an email to [email protected].
    Coming Events: (PM Jiminy with additions/corrections)
    18th Annual North Central Iowa Four Banger Speed Meet, September 11, 2021
    Hot Rod Hill Climb Sept 17th - 18th, 2021
    49th Running of the Antique Nationals October 17th 2021-Irwindale Speedway
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: [email protected]
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. Checking in from soggy Pa.
    Carter likes this.
  3. Jet96
    Jet96
    from WY
    Checking in-saw this little guy at our show this weekend. E08CFD1A-147F-4FAF-B7CA-BFEB54F63177.jpeg 99268B59-8E14-43CC-AB39-EE3BEDAFD4FF.jpeg the engine was barely longer than the generator!
  4. denis4x4
    denis4x4
    from Colorado
    Took the '29 CCPU to the Speedster Reunion and it crapped out on the first tour day. Got it home and started working on it and made some changes here and there. The wiring was marginal going in and I cut through the loom with a die grinder when I removed the throttle/advance rods. I put it in the storage garage today with boxes full of parts and it may be a future barn find! At 80 with a couple European sports cars and the Zipper roadster, I see no need to rebuild the CCPU at this time.
    Old Dawg, Jet96 and winduptoy like this.
  5. Just waiting on my intake manifold and valve cover from Burns, then this banger will run!
  6. noboD
    noboD
    30 days has September.
  7. Dustyp489
    Dustyp489
    Checking in, Carlisle is the end of the month
    winduptoy likes this.
  8. yep, czek'd in
  9. Stovebolt
    Stovebolt
    I didn't take any pictures of the day, but it is the second day of spring here day, so I took the coupe out in order to take the dog to the vet's to get some teeth extracted - it was his first time in the car - he seemed to like it.
    Crazydaddyo, Jet96 and winduptoy like this.
  10. winduptoy
    winduptoy
    Not much to say,
    Had the T out and one cylinder decided to not play well and another followed it. It was the timer and a coil after a trailer ride back home.
    Installed a new 'I-Timer' and a different rebuilt coil. The bugs no longer crash into the back side of the windshield.
    Outback, guitarguy and Jet96 like this.
  11. railcarmover
    railcarmover
    Gonna go say hi to the boys in the model a club friday,see how many i can piss off..Auburn hill climb the middle of the month,if the woods aint on fire
    BeaverMatt likes this.
  12. brjnelson
    brjnelson
    Saturday Sept 11 Iowa hillclimb
    The PDF attached has all you need to know.
    burl and Jet96 like this.
  13. Binger
    Binger
    from wyoming
    Checking in from Cheyoming!
    winduptoy and Jet96 like this.
  14. V4F
    V4F
    from middle ca.
    SOSDD
  15. Phil Damon
    Phil Damon
    from San Diego
    Checking in from San Diego.
    Jet96 likes this.
  16. Airborne34
    Airborne34
    from Texas
    582E4AB9-155C-4E39-93AC-3E87C84BFD3F.jpeg C45251C7-7A4C-4825-A2E3-6ECF4CF00F8E.jpeg I picked up a few parts from a Banger Estate. He was into Hopped up B motors in the 70’s -80’s
    I have some GM Rods that were apparently used in some of the early inserted Bearing motors. They are marked 499637 GM (Diamond Symbol) 17. Far as I can tell they were from late 30’s 6 Cylinder. I would consider them cores at best.
    If they were used back then, I’m sure there are much better options now a days.
    think there’s any value in them or should I scrap.
  17. studebakerjoe
    studebakerjoe
    @Airborne34 if you decide to get rid of them I'd be interested in them.
  18. 25mercury
    25mercury
    499637, they are Pontiac 6.
  19. Be careful, these may be a 1/16" longer center distance
    J
  20. After shock testing with the Coupe to Pendine and back including some salt bath and wet sand blasting on the beach I transferred them to the Tourer for a trip to GOW at Prescott hillclimb last weekend. Working really well. Shim valves inside and pressure filled with oil. Should be available soon from RKE Engineering in the UK.
    (Photo courtesy of Reverendpixel)
    (Photo courtesy of John Hallett)
  21. railcarmover
    railcarmover
    Just another Friday night, got tossed out of the A club meeting for talking during the gospel and general douchebaggery ...some nerve, all I asked is if anyone wants to race for pinks..my idea of a car club is a bunch of dudes talking shit, drinking beer and lying about something.. these dudes wear matching polo shirts and act like they are in church.. the treasurer said they had 41 k in the bank..They didnt like it when I yelled "kick some down, Ill get the keg and start the barbecue"...
  22. winduptoy
    winduptoy
    Yes,
    I gave up on the local Model A club years ago. They would collect dues and interest on the money in the treasury.
    Suggest that funds should be spent to the benefit of the club members...there was great pride in the funds hoarded in the coffers and it was intended it remain that way!
    Organized as a 'not for profit' Corporation, they were audited and informed that if they didn't spend some money, they would be viewed differently, status revoked and taxed.
    Jet96 likes this.
  23. railcarmover
    railcarmover
    That club has actually had their funds embezzled a few time..looks like it's getting ripe for the pickens again..
    Dannerr, Old Dawg and fourd like this.
  24. Stovebolt
    Stovebolt
    @hotrodfil is RKE the ones that makke the flywheel for a banger?
    Old Dawg likes this.
  25. V4F
    V4F
    from middle ca.
    HAPPY FATHERS DAY to our friends down under . aussie's have a great day .............. steve
    Outback, Jet96 and Midnight Rider like this.
  26. BlacktopScraper
    BlacktopScraper
    IMG_4239.jpg Just wanted to join in this group and check in. This is my '30 Roadster in the foreground and my first banger powered car.
  27. BlacktopScraper
    BlacktopScraper
    Hey Retson...
    Just curious, who made your header and are you using a Burns single or dual?
  28. Ran last month at the 2021 Rolex Monterey Motorsports Reunion. Did what it took near 60 years (on and off) going thru the "Corkscrew"! I spun! I caught it though; and didn't hit the wall! Thanks to being a life long skier; as the rear went around to the right heading the car to the inside wall; I briefly hit the brakes! I then cranked the wheel to the right and rolled on power! The car whipped around 180 degrees. That set the downhill wheels like those of ski' edges) ; and I slid down to a stop a couple of feet from the downhill wall. According to the photog, Adam Hosey who took the below photo below; the crowd went wild!
    97, BlacktopScraper, Outback and 9 others like this.
  29. Nope - it's an engineering company in Norfolk in the UK that is handily just across the way from work.
    https://rkeengineering.co.uk/
    Outback and Stovebolt like this.
  30. hardtimesainit
    hardtimesainit
    Hey Dog,
    Thanks for sharing.
    This picture is worthy of framing… very nice !!
    Yup, was always told…turn into the drift ! Guess it still works ,eh !
