Hot Rods Can anybody Identify my front axel?
Discussion in 'The Hokey Ass Message Board' started by Wageslave, Aug 31, 2021.
  1. Wageslave
    Wageslave
    from NE Florida
    I just bought this cool A coupe but it needs some help and so do I. I'm not familiar with straight front axels although I'm getting educated. What I'd need to know is who manufactured my front axel so I can get an idea of what's wrong and what's right. There's some mismatched hardware and the shocks bodies are pulled up tight against the axel beam. Are those GM spindles and disc brakes. Some of the parts appear to be common to other axels, is that possible? Anyway here are a couple of pics and any help will be appreciated. No the car is not on the road. IMG_3702.jpeg IMG_3702.jpeg IMG_3698.jpeg
    dana barlow likes this.
  2. mink
    mink
    from CT
    loudbang and dana barlow like this.
  3. 42merc
    42merc
    I see a '33-'36 axle.
    '42-'48 square spindles for cross steer.
    irishsteve and X38 like this.
  4. Mr48chev
  5. alchemy
    alchemy
    Yep, a 33-36 axle and 42-48 spindles. I don't know my disk brakes, but I'd guess they are a semi-modern bracket kit. You will probably have to show some closer pics of the calipers or see if there are any numbers on them to get them positively identified.
  6. I'd guess Henry Ford manufactured it.
  7. xlr8
    xlr8
    from Idaho
    Hard to tell from that angle but maybe 70's Firebird or Camaro brakes.
  8. Ford manufactured your axle. And I agree, 33/36.
    Someone drilled holes in it to mount shocks.
  9. Pete Eastwood
    Pete Eastwood
    from california
    What they said . . . '33 - '36 .
  10. Wageslave
    Wageslave
    from NE Florida
    Wow, Knew I came to the right place. At least I'll know what I'm asking about when I start work on it. As always a wealth of information and experience, Can't thank you guys enough. Surely there's an Alliance vendor that would have rebuild parts.
  11. Blake 27
    Blake 27
    An easy way to tell is to measure the axle thickness where the spring perch passes thru.
    36 is 2" - 37 is 2 1/4"
  12. Bikelessbill
    Bikelessbill
    Brake kit looks like one I got from Speedway.
  13. deucemac
    deucemac
    Just remember that when you order a king pin kit, order the kit to fit the spindle and not the axle. The king pin bore is the same up to 48, however the king pins are different lengths for 37-41 (78A) and 42-48 (21A).
