I've noticed a noise from my 49 front left wheel area and I thought it was the bearing going bad. I got under it today and this is what I found. Is the correct term for this upper link pin and does the wear look excessive or will it be fine just replacing the link pin and bushings? Thanks
Looks like the outer cap on that pin backed out and fell off. Has the inner part of the pin been hitting the threads in the A frame? If you're concerned that the threads in the A frame look worn or shallow they weren't very "deep" to begin with, they should match the threads on the new end cap. https://www.chevsofthe40s.com/detai...n_Upper_Outer_With_Seals_194954_Cars_and.html
