Technical ***August 2021 Banger Meet Thread - Hot August Bangers!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 1, 2021.
  1. yes, has HEX drive for the pump and a roller element thrust bearing for the cam.
    J
    Old Dawg likes this.
  2. Yeah! Brian Blain's Ragtime Racers were quite a hit! They'll be in Murphys CA on Sept.25h and Chattanooga TN Oct. 14th thru 17th. I've agreed to serve as a "Reserve" driver; but as yet not have been needed!
    fur biscuit likes this.
  3. Jet96
    Jet96
    from WY
    0350D74A-0A4E-44D4-A70B-F9826D69DAA1.jpeg My nephew cruising the roadster back in the day. About 9 yrs ago maybe?
  4. fourd
    fourd
    from Colorado
    Check out my neighbors 4 banger. 1912 REO.
    0EC8CF0E-F361-4A2A-AA9F-1E407E3F714A.jpeg 3B4E1BF0-2BAE-4C9B-8456-B06F5E318704.jpeg D8D575C1-9F5E-40FE-BFBA-AFA1B7D124F7.jpeg 15E0314E-0C11-484A-97D0-7E5029F8BE26.jpeg 5CFC38B1-6520-412A-9F06-89D209DAF612.jpeg 0EC8CF0E-F361-4A2A-AA9F-1E407E3F714A.jpeg
    barrnone50, GuyW, Old Dawg and 2 others like this.
  5. Oh Hell Yeah!!
    Love those engines with Jugs, BIG JUGGS!!
    My Buddy has a Pierce Arrow 6 Banger, 18 spark plugs and all.
    J
    Old Dawg, Jet96 and winduptoy like this.
  6. Jet96
    Jet96
    from WY
    Digging that steering gear!
  7. Does anyone make or have a cross reference for a larger OD main bearing inserts for a model B?
  8. fur biscuit
    fur biscuit
    Went to his site and read up. It is a neat idea, getting member all over the US to have cars on hand for a bit of a show. Sort of a pre-War traveling circus. Appreciate the need not to "race", but mosey around quickly. The gentleman running the REO w/the HALL-SCOTT certainly pushed it a few times, couple of off track incidents from the video.
    Jet96 and Old Dawg like this.
  9. winduptoy
    winduptoy
    Is it already inserted?
    I'm asking because there are different ways to skin the cat...
    If it isn't already the list of Model A parts providers mostly all carry Antique Engine Rebuilders, out of Skokie, Illinois, inserts.
    Jet96 likes this.
  10. Well, the cat is out of the bag. New banger build incoming!! IMG_4211.jpeg IMG_4212.jpeg
  11. The builder is in contact with Falluca the owner of Antique Engine Rebuilders, we are using his parts, he is the one that said he sees it once in a while, and that it has to be shimmed.
  12. kb9jlo
    kb9jlo
    from Central IL
    1. H.A.M.B. Chapel
    I'm probably looking for a needle in a haystack - seems there was a 'series' in Rod & Custom before it died (the last time) where the guy was gently modding a stock Model A. Nothing extravagant. Just a few little things. I want to say reversed spring eye, some other things. I want to reread that series now that I have a Model A. Don't even remember what he did to the banger but pretty sure he did something...
  13. You can download pdf catalogs from bearing manufacturers and search on size.
    I would recommend using older versions, 2000-2005, the later ones have discontinued the older bearings.
    Applications, MG, Triumph, Datsun, Buda/Perkins and Kubota.
    J
  14. Jiminy
    Jiminy
