Is it leaking gas? Dangerous fire hazard. Must be replaced/rebuilt. If you want the glass bowl type, be sure to get one for a pre ‘48 car. Is it leaking oil from the mount? If so, may just need a new gasket. Hope this helps.
You can rebuild it yourself quite easily. Your diaphram may have a rip or one of the gaskets need to be replaced. Not a big deal after all
