Preparing to rewire my A Tudor, has a stock gas tank, where did you locate your fuse box? was going for the drivers side of the inner firewall, Thanks in Advance
Think about where your rear end is hanging out if you have to work on the fuse panel along the road. My vote is pass. side
My battery is under the passenger floor, so I was thinking of putting my fuse panel behind the passenger side kick panel. Using an abs board to mount the vinyl kick panel on and using snaps (or something like that) then I can just pop it off to check.
I had to look it up and it is Painless with a few modifications done at Posies by the previous owner. No issues, except changing out fuses, in 6 yrs.
