Projects 1932 Ford Sedan build
Discussion in 'Traditional Hot Rods' started by IronFord, May 1, 2020.
  1. corndog
    corndog
    from Indiana
    I love that sedan and your work! Very cool car!
    Big mike 1968 and IronFord like this.
  2. 343w
    343w
    Great job, thanks for sharing the project pictures during build phase. I wouldn't worry much about how long it took, I've been collecting parts on here for over 10 years for my tudor!
  3. Great history on the tudor. Love what you have done with the chassis. The driveline combination should serve you well if you don't drive it like you stole it. One of my pals has a 5 window done pretty much the same - since 1972 - and he hasn't broke much on it.
    Good job.
  4. ROBRAM
    ROBRAM
    If you don't mind me asking, where'd you get those new dual function gauges?
    IronFord likes this.
  5. So-cal Tex
    So-cal Tex
    Very Nice garage build, I love it!!
  6. sliceddeuce
    sliceddeuce
  7. scotti32
    scotti32
    Very cool tudor
  8. IronFord
    IronFord
    from NoDak
    ROBRAM the dual function gauges are from Westach. https://www.westach.com
  9. ROBRAM
    ROBRAM
    Thanks IronFord. Iv'e got to get me some of those gauges!
  10. NealinCA
    NealinCA
    Very nice!
    kidcampbell71 and IronFord like this.
  11. hotrodlane
    hotrodlane
    Awesome! It is obvious you done your homework before building this sedan as All the components you collected and used makes the perfect 32 build. I see from your rear model A crossmember Edward Lloyd also had some influence on your build. I really like your use of the front 32 motor mounts on the small block.
  12. SPEC
    SPEC
    Great patina!
  13. IronFord
    IronFord
    from NoDak
    I still working on this thing. It’s just about ready to fire. 7B5A422D-4686-4506-B50E-9977EA151CBD.jpeg 918C9673-D759-4537-817F-A14F496CED40.jpeg D79E112F-000A-4F56-A158-022F793858BE.jpeg 692A85F8-C4AF-478D-A102-479C71BB4833.jpeg F30D6333-1837-4E28-9E91-F5B4EF41C40E.jpeg CD385175-B716-41F6-8F16-F2953C1DDDE6.jpeg
  14. watain
    watain
  15. Good looking car and above all it sit's right.
    What's the wheels and tires? HRP
  16. Great build. Keep the updates coming.
  17. That’s a great sedan! Well done!
  18. Big mike 1968
    Big mike 1968
    Love the stance and looks of this car. It's not flashy or gaudy, just a solid old school hotrod. Well done
  19. T&A Flathead
    T&A Flathead
    I bet that old spirit is thrilled to be back on the road.
    Big mike 1968 likes this.
  20. IronFord
    IronFord
    from NoDak
    The rears are 16x5 original fords. The fronts are 40 Ford style 16x4.5 aftermarket. 7.50s in the back 5.50s in front with excelsior tires.
  21. bangngears
    bangngears
    from ofallon mo
    I enjoyed your build. Very nice workmanship. One thing comes to mind and that is your front motor mounts. I had issues years ago when i changed an engine for a guy that had the old Hurst mount that had the center removed because he put a larger balancer on. With that modification the engine movement loosened up the bolts and ate out the bolt holes We changed out the engine and added a piece back to tie the 2 outers together again. Solved the problem. Your mounts are beautiful and well made, but i would safety wire the bolts so they can not back out or tie them together to prevent the same thing happening. I am in no way knocking any of your workmanship, just saying what i saw on the engine swap i did on a 40 coupe. Nice work, will continue to follow
    deathrowdave likes this.
  22. IronFord
    IronFord
    from NoDak
    We got her fired up for the first time over the weekend.
  23. IronFord
    IronFord
    from NoDak
    Thanks, everything on this car has been drilled and cotter pinned. Just like When it left the factory.
  24. SPEC
    SPEC
    Sounds great.
  25. Great thread and build, congrats!
  26. IronFord
    IronFord
    from NoDak
    Thanks everyone. She made the trip to Watertown, Sd a few weeks ago for the Vintiques car show. No major issues other then some exhaust rub. I did have to oil the leather seals in the Columbia canister when we got to Watertown. 91267F33-2926-4785-B530-8B229A9CF867.jpeg 8CBD2BE3-F227-4415-955C-65F72F9CC0D6.jpeg
  27. typo41
    typo41
    NICE look, keep it of you can!!!!!!!!
  28. jakesbackyard
    jakesbackyard
    from ND
    1. Upholstery
    Just came across the build thread. Darn nice work Luke. One of these days I’ll have to see it … and the ‘40. Love them both.
    IronFord and kidcampbell71 like this.
  29. brady1929
    brady1929
  30. IronFord
    IronFord
    from NoDak
    02D2F357-3AA3-4F20-8FCA-F4F8B2230BF8.jpeg 57F7EFFF-26C7-4B95-B180-EEE4FBF66B8C.jpeg 0D5D6A27-FB4E-498D-9BC6-563EFE80ACDF.jpeg 334C17D4-09F3-4239-827A-D509C684EAD4.jpeg 02D2F357-3AA3-4F20-8FCA-F4F8B2230BF8.jpeg 57F7EFFF-26C7-4B95-B180-EEE4FBF66B8C.jpeg 0D5D6A27-FB4E-498D-9BC6-563EFE80ACDF.jpeg 334C17D4-09F3-4239-827A-D509C684EAD4.jpeg D659C533-08FF-4EE2-A2A4-C88DC6D3285D.jpeg Starting to get some miles on it now.
    deuceman32, rod1, Drylake and 3 others like this.
