Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. ^^^^may not be finished Paul but it is one of my favorites. Screams real hot hot!
    Stogy, loudbang, Paul and 1 other person like this.
  2. Paul
    Paul
    Editor
    Frame's all welded, checked for flat and square and started clean up for paint
    Lil'Alb, OFT, jebbesen and 10 others like this.
  3. Paul
    Paul
    Editor
    Started priming the frame with rattle can paint I bought a year ago, I've had good results with the brand in the past but not so much today.
    Two cans spitting and dripping..
    So I tacked the firewall in place.
    bchctybob, Tim, Lil'Alb and 13 others like this.
  4. Paul
    Paul
    Editor
    Bought new primer, rattle can again,
    shake, shake, shake,
    Spray and Scotch-Brite
    Put together a simple rotisserie
    bchctybob, patmanta, brEad and 10 others like this.
  5. jebbesen
    jebbesen
    from Winona, MN
    You really do nice work. I like the sawzall paint shaker too! Brilliant!
  6. Paul
    Paul
    Editor
    Semi gloss enamel
  7. Paul
    Paul
    Editor
    Threw together a rack and started painting some of the bits and pieces
    Stogy, bct, bchctybob and 11 others like this.
  8. alchemy
    alchemy
    Your girlfriend sure looks grumpy.
    Jet96, Stogy, kidcampbell71 and 3 others like this.
  9. lake_harley
    lake_harley
    I think she's in time-out. Paul has made her stand there for a long time now.
    Lynn
    Stogy, loudbang and Paul like this.
  10. alchemy
    alchemy
    She's upset the parts aren't being chromed to coordinate with her outfit (and skin).
    30tudor, Stogy, bct and 3 others like this.
  11. Paul
    Paul
    Editor
    Parts slowly going back on the frame
    Shadow Creek, OFT, warbird1 and 12 others like this.
  12. Stogy
    Stogy
    :rolleyes:....Good Times Indeed...Lovin the Journey...Hotrod Paul's Garage...This garage shot above rocks....Lots to like...
    Paul, loudbang and AHotRod like this.
  13. With your ambition we will see the driving video this Friday??:rolleyes::):)
    Stogy, Paul, loudbang and 2 others like this.
  14. Tim
    Tim
    from KCMO
    Looking good
    Stogy, Paul and kidcampbell71 like this.
  15. coming together nice Paul !
  16. Paul
    Paul
    Editor
    working on chassis assembly some more.
    front got new king pins, bearings, seals, shoes, cylinders, hardware and drums turned.
    rear got new pinion seal, new axle bearings and seals, new shoes, cylinders, hardware and drums turned.
    rear brakes will have to be opened back up for parking brake cables. Gotta order them yet..
    I was short on self adjuster hardware, needed one actuator link.. so I left them out
    it'll be manual adjustments front and rear.
    PXL_20210713_012131960.jpg PXL_20210713_005713493.jpg PXL_20210713_223100188.jpg PXL_20210714_002547591.jpg PXL_20210712_175213158.jpg PXL_20210715_223746143.jpg
  17. Paul
    Paul
    Editor
    chassis back on four wheels again
    rolled outside for pix
    PXL_20210715_231951830.jpg PXL_20210715_232001088.jpg PXL_20210715_232011725.jpg PXL_20210715_232018589.jpg PXL_20210715_232035347.jpg PXL_20210715_232045674.jpg PXL_20210715_232102479.jpg PXL_20210715_232123911.jpg PXL_20210715_232139881.jpg
  18. Paul
    Paul
    Editor
    Simple bracket to bolt the clutch slave cylinder to.
    Needs a longer rod but you get the idea..
    sko_ford, warbird1, bct and 9 others like this.
  19. Tim
    Tim
    from KCMO
  20. OFT
    OFT
    Coming along nicely!
    loudbang, Stogy and Paul like this.
  21. Another bitchen car coming out of your garage. Oldsmobile powered of course.
    loudbang, Paul and Stogy like this.
  22. Dago 88
    Dago 88
  23. Paul
    Paul
    Editor
  24. Beanscoot
    Beanscoot
    Those quad headlights are a bit weird.
    Stogy, loudbang and Dago 88 like this.
  25. Dago 88
    Dago 88
    It was the 60's man, they got away with shit like that. ;)
    Stogy and loudbang like this.
  26. loudbang
    I was too busy looking at the supercharger to notice the headlights. :rolleyes:
    Stogy, Tman, bchctybob and 2 others like this.
  27. Paul
    Paul
    Editor
    Frame becomes chassis
    PXL_20210727_182140840.jpg PXL_20210727_182111623.jpg PXL_20210727_182009604.jpg PXL_20210727_181918969.jpg PXL_20210727_182022290.jpg
    Tman, bchctybob, Stogy and 17 others like this.
  28. Lookin good!
    kidcampbell71, loudbang and Paul like this.
