Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. Love the shifter Gary.:) Very nice.;)
  2. loudbang
    Looks good :)
  3. Nice work as always!
    M/T knob is cool.
  4. Yea! The M/T knob is killer!;) Are you almost ready for a test drive? :)
  5. 2.5" exhaust with 24" Thrush glass-packs.
    They're quieter than I remember :confused:
    But give 'em time...:cool:
  6. Dino 64
    Dino 64
    from Virginia
    You were focusing on the engine sounds, it was loud, believe :rolleyes::rolleyes::)…. It was a wonderful sound too;);)
    Stogy, loudbang, mad mikey and 2 others like this.
  7. There was no room for my stock pistol-grip E-brake. :(
    But this Lokar unit fits under the driver's knees.
    Will connect the cables when the tires are down off the cribbing.
    I also whipped up a license plate bracket that hangs from the spare tire mount holes.
    A racing buddy's expired license served as a template. :cool: 20210225_162013_2.jpg
    shortypu, TFoch, Stogy and 14 others like this.
  8. Tim
    Tim
    from KCMO
    Looks heavy lmao
    Stogy and Just Gary like this.
  9. brianf31
    brianf31
    Nice license plate. Nitro!
  10. Incredbile build, thanks for posting!!
  11. Hey Gary! I have the same e- brake in the coupe, works great. :)Excellent choice my friend .;)
    Stogy, loudbang and Just Gary like this.
  12. Roothawg
    Roothawg
    Bump since I can never find this when I am looking for it….
    Outback, mad mikey, brandon and 4 others like this.
  13. I scored an NOS, made-in-the-USA Stewart Warner speedo to use instead of the restored '56 Studebaker/SW speedo I'd previously gotten.
    A daughter's wedding & son's college bills devoured this month's budget. To keep up momentum, I set aside the $hopping list and attacked my low/no-cost task list:
    1) @ol55 , a fellow Classic Chevy Club buddy, donated a pair of "old-chrome-but-I'm-painting-'em-black-anyway" exhaust tips. Thanks, Larry! :)
    Hi-temp exhaust paint:
    2) I'd already hammer/dolly'd and shrink-disc'd the sheetmetal as straight as possible. So I scuffed the epoxy primer and spread a thin (~1/8") coat of "Rage Gold" filler on all the remaining ripples & low spots. #80 on a longboard will remove most of it.
    After that, I'm not sure. Maybe go back & skim-coat the entire body? Or maybe continue to #180 & #240 then straight to hi-build polyester primer?
    Yes, the body is that straight (I think).:confused:
  14. Dino 64
    Dino 64
    from Virginia
    IMHO, skim all of it, don’t go finer than 180 before primer. once your start sanding, you’ll find more spots to fill. :eek::rolleyes::)
  15. 32fenderless
    32fenderless
    This is one of my favorite builds on here. Keep up the great work.
    mad mikey, loudbang and Just Gary like this.
  16. brandon
    brandon
    Cool to find this post...
    lothiandon1940 and Just Gary like this.
  17. "Anything that falls to the ground when you let it go from your hand is way too heavy to be on my race car."
    -"Sneaky Pete" Robinson
    The battery box is 0.75"x 0.75" angle, sized for an Odyssey 680.
    It fits under the rear passenger floorboard. Frame tabs are 1.5" x 1.5" angle.
    I also made an easily-removable under-dash electrical panel.
    There's room for an MSD box, coil, and fuse panel, with extra space for relays, USB ports & future growth.
    It's just 20 ga steel...
    ...and bolts to what's left of the stock gas tank.
    Insulation will fit in the 1" gap between it and the stock firewall. :)
    :cool:
    Outback, Gotgas, shortypu and 10 others like this.
  18. -Brent-
    -Brent-
    This is such a badass car/build.
  19. NHRA requires a locking dipstick & securely fastened fill tube on all automatic cars running 10.99 (6.99 1/8 mile) seconds and quicker.
    I'm nowhere near that quick, but thought adapting one might be wise.
    "Hack hack!"
    I ground off the gold iridite coating wherever I'd be welding; then fine-tune my MIG settings by practicing on the tube scraps.
    The spring steel dipstick got trimmed & new high & low level notches added.
    The tab bolts to a convenient transmission case lug.
    Snug fit but functional; and simple. :cool:
    Finally, I've laid under this car with a tape measure & cardboard cutouts for hours, wondering where to squeeze in all the components.
    The last puzzle piece was a 24" "tube & fin" trans fluid cooler, attached to the driver's side frame rail, well away from the exhaust.
    Brackets allow lots of air flow all around.
    5' long hoses might also give a bit of cooling capacity.
    -6 AN fittings. Go Navy! Beat Army! Ha ha! :D
  20. Dino 64
    Dino 64
    from Virginia
    Nice clean install, shouldn’t have any problems with the cooler with AN lines. Good job !:)
  21. Roothawg
    Roothawg
    Gary, it looks very sanitary.
  22. catdad49
    catdad49
    Gary, what do you do in your “Free” time?!
  23. I like it, all of it. Funny ,I did nearly the same thing on my coupe. Hey , great minds think alike. LOL.:)
  24. Man you’re getting close. Been following your work for a long time now and the end is in sight. Congratulations on seeing it through. This will be a stellar ride.
  25. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Outstanding Thread and just a killer build Gary...so very nice.
  26. Roothawg
    Roothawg
    I like the cardboard mock ups. Use the crap out of old Summit boxes.
  27. ol55
    ol55
    from Virginia
    Thanks for sending me this link Gary. Not sure why I was not following, but I am now!
  28. Foot-shaped Moon, Cragar & Cal Custom gas pedals were common on mid '60's drag cars.
    A skinny rectangular Moon pedal would've fit the narrow footwell, but I carved up my cherished swapmeet piece instead. :oops:
    The top piece screws into aftermarket linkage.
    Despite measuring a zillion times, my firewall mounting holes weren't quite right so I welded them up and redrilled 'em. I also added fender washers on the engine side of the firewall to prevent wobbling.
    The bottom "heel cup" bolts to the floor where my foot naturally falls. The bracket flexes a bit so no hinge is required.
    Finally, the leftover middle piece underwent "gender reassignment surgery" to become a brake pedal. :eek:
    A 1/2-20 bolt threads into the P&J brake arm.
    Everything fits comfortably & functions beautifully. :)
    Even wearing Bean boots (it's 40* F in the garage).
    Thanks to @Dino 64 for being my sanity check.
    Outback, gonzo, chevy57dude and 25 others like this.
  29. Tim
    Tim
    from KCMO
    Oh man I really like that!
  30. Like it alot Gary.:) I had to slightly modify my vintage moon pedal as well. Had to cut a small amount of the toe area off, to clear the fire wall at full throttle.;)
