Technical First ride!
Discussion in 'Traditional Hot Rods' started by Willywash, Jul 24, 2021.
  1. Willywash
    Willywash
    Just took my 31A hot rod for its first test drive. Just went up and down the street a few times making sure nothing was over looked. The car settled on the drivers side about an inch, front and back. Knowing the car is a bit heavier on the drivers side, do you have to adjust coil over stiffer on the lower side. I don't think there's anyway to make the leaf spring on front stiffer on one side. Anyone have suggestions?
    Big mike 1968 likes this.
  2. Go on a diet
    Jibs, kadillackid, X38 and 1 other person like this.
  3. Jokester
    Jokester
    Take a passenger that is about your size.
    .bjb
  4. gary macdonald
    gary macdonald
    Possibly relocating the battery to passengers side .
  5. dan31
    dan31
    Yes, adjust coil over . Congrats on the first ride, pretty cool.
  6. birdman1
    birdman1
    gotta keep those first rides close to home! congrats!!
  7. Big mike 1968
    Big mike 1968
    You need someone big like me to settle the pass springs and I volunteer.
  8. Deuce Daddy Don
    Deuce Daddy Don
    Don't know if you are using "buggy spring" or not, but I used a kit for parallel leaf on each side which cured the "lean" problem. especially on mountain curves.-----Don
    Hamtown Al likes this.
