Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. Piewagn
    Piewagn
    Thanks for your concern Rod! The coil and resistor setup came that way. We'll see how it goes. I want to keep the firewall and engine as tidy as I can and there's no real ideal location to mount the coil out there. I have run a setup like this before on my truck....same deal, wanted to keep things minimal. I DO however have a small vacuum fan I was gonna stick under the dash too....to we'll see......and yes, I was planning on just the center carb until things settle. The linkage isn't even tight. Thanks for hangin'!!
  2. Piewagn
    Piewagn
    Driver side done!! Well, except for the hangers which are on the way....
    Now I can make templates for the floors and cut them this weekend.... I start finishing up the wiring once the floors are secured.... Then it’s on to all the odds and ends....it’s been a long road to hoe fellas and it’s all starting to pay off!
    7F24E768-A229-4D3F-B50F-1DFCC1CEE8EE.jpeg 7AF109E7-F2F6-4B3F-99A8-5EFC7D13A5FF.jpeg 40F40996-B2A0-4020-BAC1-C83225274D40.jpeg E664F40F-992E-4ABD-9BD4-E9B4DB5715D0.jpeg
  3. RodStRace
    RodStRace
    Just a wild thought, since you are doing such a nice job with the build.
    Exhaust even without modern stuff gets hot over time. Since you built the whole system without a floor and it's still open, have you thought about hanging shielding too?
    It would help any sound/heat insulation you plan to lay down later.
    Around town is fine, but if this is going on all day jaunts, it could make it more comfortable.
    The main point I see are those first bends to horizontal right under the floor, which are going to get warm on the outside of the bends, pointing right under your backside, and whatever might be stored under there, if anything.
    Piewagn, greaser and loudbang like this.
  4. Piewagn
    Piewagn
    Oh yes....heat shielding going in place....we’ve got a ton of aluminum and stainless sheets around here. Your input is greatly appreciated....thanks Rod!
    Nicholas Coe, RodStRace and loudbang like this.
  5. Piewagn
    Piewagn
    Got new bulb sockets and bulbs installed in my tail lamps, made a bracket for my continuous duty main power switches and made templates for my floor panels. I brought them home with me so I can cut them this weekend. Enjoy your weekend everyone!
    4BF776DC-FE94-4F58-97E0-850F13D52182.jpeg 11C753A8-1BD5-4F5A-91AF-9BCDC15B5CB0.jpeg
  6. Piewagn
    Piewagn
    Floors cut, sanded and stained.....
    ”slate” it’s called. Another big step done! No remarks about the garage! I know! It’s been neglected since I started building the coupe. Have a great weekend everyone!
    E73D812F-3AFA-4D16-8AC2-043BF55710F0.jpeg BFA58BB2-3A11-445B-B720-1E3E02F8C0DE.jpeg F76A825F-6FD9-4CCD-B8A7-A5D320CF713F.jpeg
    Vic Walter, RodStRace, brEad and 5 others like this.
  7. Piewagn
    Piewagn
    Had to make female hoops for the transmission ends of the shift linkage....I’ll be welding them to turnbuckles so I can make my linkage adjustable. I’ll post pics when linkages are complete.....try and stay cool fellas!
    027B537B-F14B-435E-9579-E97E072ED028.jpeg 5E2EA72D-C818-4C01-96A6-97B4238D2890.jpeg 21A049D6-091C-4ED6-8A8B-655F6D1B9EA5.jpeg
  8. Piewagn
    Piewagn
    I’m likin’ it! Came out better than I thought....considering the cobbled together sedan/roadster/coupe subframe!
    07E36CB3-A15B-4BBC-8B53-6BECA17BB7AB.jpeg 96763325-C497-4CA0-A1B6-71036BED08DC.jpeg 3536D62D-4409-4203-813E-DCD082AD244B.jpeg
  9. Piewagn
    Piewagn
    Harley Davidson brake light switch! I did have to shorten it and put the inverted flare in it....should work great! Body mounts in and tight....now I’m mocking up gas tank location and frame cover panel. I’ll take care of the trunk firewall once I get the tank secured in it’s permanent home. Thanks for stoppin’ by fellas!
    F09A6D6A-C863-40C8-9C16-2704DF2EF4B3.jpeg 1793B198-66D4-44A6-AF0E-6D35FC32C258.jpeg 2685FE33-662E-480B-9D41-CAB754C7AB46.jpeg CAFE3E91-1ED0-4026-8598-BE2D176CA7A9.jpeg
  10. Piewagn
    Piewagn
    Heat shielding in place, finished the crossmember cover and mounted my main power switches.....rollin’ right along!
    91B0DFBB-0CA1-4891-AE2B-A4B24B6FE2DC.jpeg D4088E21-BB92-4C02-AA65-E7A7F794525D.jpeg 02E47394-FDEA-49A7-A827-C9A143013E54.jpeg AD8B4A3A-A599-4FC4-BD16-A363FC1370DA.jpeg
  11. Piewagn
    Piewagn
    Got my package tray blasted, painted and installed....also got my brake and clutch linkages hooked up and pedals sorted. They were hitting the column so they were in need of some attention....I’m just checkin’ sh*t right off my list! Stay cool everyone!
    E59025FB-1E24-414A-BBBF-4F03FBF12FDF.jpeg 9A83E658-A243-4093-93CC-4D222CD3E80E.jpeg
  12. Getting closer…..first drive by August 1st?
  13. Piewagn
    Piewagn
    Oh man....I'm hoping! I may take a weeks vacation and thrash on the wiring....it's all nitpicky stuff now...
  14. Piewagn
    Piewagn
    Rear lamps secured and wired! I’ll run the fuel sender and pump forward in separate harness, I’d rather keep the lighting harness isolated. It’ll be all neat and tidy....have a great weekend everyone!
  15. Piewagn
    Piewagn
    Seat finished! This’ll do just fine...Just have to tidy up the frame and make some type of riser.
    7D9BDAF1-490F-4F01-BCEB-4C876505109A.jpeg 8D9010F1-4A47-45EA-AE91-5B07560456B6.jpeg
  16. loudbang
    Seat came out great. :)
    Nicholas Coe and Piewagn like this.
  17. Piewagn
    Piewagn
    Thanks LB! I’ve sublet NOTHING on this build and have done everything myself, so I figured why not do the seats to....so I gave it a go....
    Aaron D., Nicholas Coe, brEad and 2 others like this.
  18. Piewagn
    Piewagn
    Headlamps, brake lights and turn signals wired! The red and white wires will be going to my hi/low switch. Now as soon as my fuse block comes, I can wire my main power and B+ for everything! That little bit of harness between the frame and column is all you can see from the outside.....the inside will be just as invisible when I’m done..... have a happy!!
    2024084F-6F1C-42BB-981C-7473AC148B09.jpeg 57A04F96-B25B-4250-9E51-A914DFC4ED9D.jpeg
  19. Piewagn
    Piewagn
    Made my own lic plate bracket, it also accommodates the Chevy tag lamp assembly! Made a gasket for it and tapped into the park lamp circuit. I’ve knocked a huge chunk off my check list.....the remaining list is getting smaller .....that much closer yo driving!
    Ok....want a couple opinions from you guys. Leave the vintage reflector? Also, which tag do you guys prefer? I’m kinda partial to the crusty one. Whaddya you all think? Thanks fellas!!
    6401E705-BB15-4FF6-A6A0-89E1A4786F5A.jpeg 44EAF99C-5C61-4F58-9523-8498B80D636C.jpeg B7F9CC91-E361-4843-9F44-2363CBE8249B.jpeg 62FF06AF-21CE-4C54-A6E6-95D276058BF1.jpeg 26EFBB5C-5A98-4DA7-AF47-87AA228FB443.jpeg
  20. patman
    patman
    Crusty. Definitely the crusty one.
    Nicholas Coe, loudbang and Piewagn like this.
  21. Piewagn
    Piewagn
    YES!! Thank you patman!!
  22. Osoty
    Osoty
    I vote crispy plate. I've been patiently waiting to see your tail lights lit up. Brilliant on the dykem, I may poach that idea. So close, keep thrashing
    Piewagn, Nicholas Coe and loudbang like this.
  23. I vote crusty plate, no reflector.
    pivir123, Piewagn and Nicholas Coe like this.
  24. Piewagn
    Piewagn
    I’m thinking crusty too! Poach away bro! That’s why I shared the idea!!!
  25. Piewagn
    Piewagn
    Yep....crusty plate is popular....everyone split on the reflector....maybe I’ll hang it every other cruise....
  26. loudbang
    Crusty and reflector :)
    Piewagn and Big mike 1968 like this.
  27. Big mike 1968
    Big mike 1968
    Wow, what a great thread. I started reading yesterday and couldn't stop. The workmanship is awesome, this reads like a how to book on how to build a cool hot rod. I can't wait to see it run.
    Piewagn and loudbang like this.
  28. Piewagn
    Piewagn
    Wow! Thanks Mike! Welcome and check back often. I usually have updates every evening....I’m glad you found this thread!
    loudbang and Big mike 1968 like this.
  29. Piewagn
    Piewagn
    Yep LB.... I think that’s the way I’m goin! Thanks for bein’ here!
  30. Piewagn
    Piewagn
    Here is my custom shift linkage I was telling you about....adjustable and all!!
