Customs In which order should I layer them
Discussion in 'The Hokey Ass Message Board' started by cluxford, Jul 9, 2021.
  1. cluxford
    cluxford
    from Australia
    350 SBC in a 61 Buick.
    Currently no AC. Going to install a Classic Auto Air system.
    I've never done such an install before so a complete noob !
    I have a custom radiator with 18" flex fan and no shroud.
    Will be adding a shroud
    TH350 Trans runs a transcooler, currently in front of radiator.
    I will be looking to get a large condenser, I can go as much as 25" wide and 18" deep to sit in from of entire radiator.
    My question is order...from grille backwards
    Should I go:
    Option 1
    Transcooler
    then behind that condenser
    then behind that radiator
    OR
    Option 2
    Condensor
    behind that trans cooler
    Note trans cooler only takes up about half over sq foot size of radiator and I will be going a decent sized (much larger) condenser.
    Thanks in advance for your advice.
  2. Condenser in the middle, with gaps between all of them.
  3. Sandgroper
    Sandgroper
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    My work truck has condenser , trans cooler , radiator. Been that way for 20 years & 225 k miles.
  5. What about option three? Trans cooler in the radiator?
    A shroud is a good idea, but have you considered the front of the cooling area? The air will flow around the coolers if the front of them is not blocked off.
  6. southcross2631
    southcross2631
    I did a 57 Ford 312 auto and used option 2 and it worked fine for years. I also installed a pusher fan in front of the condenser so the a/c would cool better in the hot Florida summers while sitting in traffic.
    I still kept my mechanical fan with a home built shroud. It just needed more circulation in city traffic.
    The engine never got hot , but the in cab temps would rise due to lack of air circulation. Installed a pusher fan with the switch hooked to the a/c control. After that it was nice and cold even in high 90 degree weather.
    Truckdoctor Andy likes this.
  7. Elcohaulic
    Elcohaulic
    I would get a nice thick radiator from Champion with the transmission cooler/heater built in...
    The transmission should be around the same temperature as the engine.. It needs to be heated as well as cooled.. My transmission rebuilder told me this when he rebuilt my hydro. I noticed the older hydros didn't have any coolers.
  8. squirrel
    they probably don't have a torque converter, just a fluid coupling? There is a difference in how much heat they generate.
    Elcohaulic likes this.
  9. 51504bat
    51504bat
    This might help:
    Almostdone likes this.
  10. squirrel
    If you want something to work best, put it in front, so it gets the coolest air.
    Now, you just have to figure out which is most important.
  11. lucas doolin
    lucas doolin
    Putting the trans or P/S cooler in the radiator or A/C condenser is the approach auto manufacturers use to save money - it's just an added loop of tubing inside the unit. The tubing is subject to failure and can lead to ATF in the coolant (and the reverse). Mopar got it right by using a separate small radiator out front. In the event of failure, you'll have an ATF or P/S leak but you won't damage the P/S or trans. Also, it's cheaper and way easier to replace a small accessory radiator than the cooling system radiator or A/C condenser.
  12. Not the best photo, but you may be able to see where the filler panel is below the condenser. This insures the air is pulled through the condenser and doesn't travel around it.
    Packrat likes this.
