Technical ***July 2021 Banger Meet Thread - Happy 4 Cylinders!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jul 1, 2021.
  1. Jiminy
    Jiminy
    Link to previous month: https://www.jalopyjournal.com/forum...ger-meet-thread-hows-your-4-cylinder.1231720/
    Old Dawg informs us there is an effort to resurrect a F.A.S.T. newsletter but it would require 400 subscribers (minimum number to attract vendors). Subscription price is unknown at this point (2021/7/1) but if you are interested send an email to [email protected].
    Coming Events: (PM Jiminy with additions/corrections)
    Monterey Car Week August 7th - 14th, 2021
    Bonneville Speedweek August 7th - 13th, 2021
    Hot Rod Hill Climb Sept 17th - 18th, 2021
    49th Running of the Antique Nationals October 17th 2021-Irwindale Speedway
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: [email protected]
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. Checking in!
    Much hasn't changed from last month as I've been working on the suspension for the T.
    Engine needs one more coat of paint, I ran out halfway (as you can see)
    Got a few parts bolted up to the banger. Gasket kit should be getting here soon, but I'm in need of a decent timing gear for the front.
    I got my waterpump from Sacramento Vintage Ford, they bored it to accept a large ball bearing.
    GuyW, Outback, Old Dawg and 2 others like this.
  3. noboD
    noboD
    july already ??
  4. Checking in
  5. denis4x4
    denis4x4
    from Colorado
    Three cylinder Tahatso cruising Vallecito
    Outback, Old Dawg and Jet96 like this.
  6. Jet96
    Jet96
    from WY
    Checking in from the unseasonably (unreasonably?) hot Rocky Mountains...
  7. G_Don
    G_Don
    Anyone running a thomas head? What did you use for your distributor shaft? The head is 0.25" taller than stock, but distributor shafts available from retailers never come with a lengh dimension in the product description.
    My current one is 5.75" and I need one that is 6"... will I just need to have this made? And if so, does it need to be hardened steel or is soft ok?
    Thanks for your time,
    Gordy
  8. Not rushing it, SpeedWeek is coming too damn fast.
    Trans in push truck fixed, race car is going back together.
    J
    nutrocker, Outback and Old Dawg like this.
  9. Crazydaddyo
    Crazydaddyo
    I made mine out of drill rod. (O-1 un heat treated)
    Old Dawg and G_Don like this.
  10. Checking in
    Parts arrived from the states, always a good day
    Got the gearbox in for a trail fit, enough room for the t t clamshell
    tomkelly88, Outback, ottoman and 7 others like this.
  11. Dustyp489
    Dustyp489
    Checking in, not much going on
    Skip
  12. V4F
    V4F
    from middle ca.
    same ole commy ca.
    GuyW likes this.
  13. railcarmover
    railcarmover
    Chasing tail on the dating sites..man is that a jungle,all kinds out there.The model A is a great trolling lure,plenty of hits :)
  14. atleast we're not on fire YET!
  15. Easy on that, it has been hot enough for spontaneous combustion.
    J
    Old Dawg and BeaverMatt like this.
  16. Phil Damon
    Phil Damon
    from San Diego
    I'm in. Still waiting on parts.
  17. Jet96
    Jet96
    from WY
    @G_Don -my Brierley head came with a longer distributor shaft. I don't know if Jim makes them or sources them from someone else. You might check with him...
    Crazydaddyo and G_Don like this.
  18. RussTee
    RussTee
  19. railcarmover
    railcarmover
    Got a funny one.. this woman hits me up and we start texting.. the usual first time stuff, twenty five questions about shit you don't want to talk about.. but I play pretty good.. this one however was deadly, I can talk a good game but she's pinning me down like a tail on a donkey. Get all done and i tell her Im an old knuckle dragger mechanic.. she smiles and says shes a criminal defense lawyer..
    kb9jlo, tomkelly88 and Outback like this.
  20. 6ABD95F7-AE56-44A0-9956-5F548C4C4071.jpeg 6A64DDAC-B6F3-4994-B961-59D485C6D650.jpeg Been hella day
    Started with course prep at ElMirage for next weekend
    Then Son Owen putting body mounts on chassis
    51 mercules, burl, Old Dawg and 7 others like this.
  21. Binger
    Binger
    from wyoming
    Checking in from Cheyoming.
    Jet96 likes this.
  22. Popped to a local company at the weekend to fit a set of their prototype Model A shocks. Plan is to to clock some miles on them driving the pretty route through the mountains down to Pendine, racing on the beach, and then the long weary drive home. Then strip them down and check them over when I get back.
    As they’re just across the way from work I’ve been following progress. Supplied them with a heap of original parts to work from.
    Anyway how are they? Pretty damn impressive so far after a quick blast around the estate and a charge home along some potholed country lanes.
    KiWinUS, Old Dawg, akkhotrod and 12 others like this.
  23. poshdbs
    poshdbs
    See you on the sand Phil, looking forward to it!
    hotrodfil likes this.
  24. Just in from SCTA;
    July El Mirage meet is cancelled due to expected high temps.
    J
  25. I was just thinking, has anyone actually ran this SoS front timing cover?
    Gruntis and KiWinUS like this.
  26. GuyW
    GuyW
    Hey Retson:
    Does this car look familiar? It came to me from your neighborhood
    Jet96 likes this.
  27. Outback
    Outback
    from NE Vic
    Gday all, at work we play with bangers however mostly continental vintage/veteran types.
    We also have a gaggle of specials about.
    Its for one of these I ask the question.
    We are trying to avoid getting getting a crown wheel & pinion made & need a lower diff ratio than standard. the crown wheel is smaller (in dia) than A model, I was wondering what dia is the T model crown wheel & what is the quality of the repro crown wheel/pinions like? This car will be running a 90CI HAL & get punted at race tracks. Thx
  28. nutrocker
    nutrocker
    Well, the car is finally all together and running well with just a few days left till Pendine Sands.
    I’ve had to change the exhaust to four shorties as the four into one lake style headers were glowing red at around 3000rpm. Cam overlap and waisted spark ignition means flames were heating the exhaust too much.
    It’s fun on the road though. Spinning the rears in all three gears, but the rod brakes suck. Need to spend more time than I have at present going through them.
    707EDBD9-B0AE-4C7C-ABF6-27526BA426B8.jpeg 2EF8AFA2-0537-42B3-A8AD-C293A9483F34.jpeg 467F5DD9-84A8-4C41-BD1E-1F90476EBFCA.jpeg E465A3B7-DD67-4660-B3F2-416965051797.jpeg E2958007-6354-4B5D-97D8-19D5A922BD88.jpeg 59C257F8-A17A-452F-8A39-61F04B6E6B75.jpeg E57BBCD4-17A4-4FDC-B293-75501A32E9E9.jpeg 15DF4B9C-34DB-40A8-8B5B-456240B39601.jpeg 26AC2235-F431-4A67-8B7C-A191B3BBDEDD.jpeg
    burl, KiWinUS, cactus1 and 17 others like this.
  29. rally1
    rally1
    Have just over 1k miles on mine.
    BeaverMatt likes this.
  30. I don’t reckon I’ve seen that car before. Where is he from?
